Hi I have a Xbox 360 up for grabs comes with 9 games and controller and remote, very good condition never use so I need it gone, also have a Acer laptop which I don't need anymore,Acer Extensa 5630, Intel Core2 Duo,Windows Vista Basic, Wireless,Bluetooth connectivity, Excellent condition, Comes with charger
$250 Ono- xbox360
$300- Acer Laptop
hey mate dont jump all over me here as im just trying to help, but the newer version of the xbox is only 199 brand new. these tend to go for between 50 -90.
deal with a lot of xbox's (i repair them).
The newer version is no different to the first except for 32gb harddrive,it's not only the console but comes with few hundred $$ worth of games to mate so don't appreciate ur input.
By the way if that xbox has a 2006 sticker on it, it simply will not sell. The 2006 xbox's had a failure rate of over 98% in the first 2 years. Just a heads up.
$250 Ono- xbox360
$300- Acer Laptop
Yeah sorry dude that's way over priced. I picked up a brand new 360, 320gb with 4 games for $299
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
