I have One of these units for sale.Its from a Vspec and can be fitted to any vehicle at all not just a skyline.For those that dont know these units displays Throttle position,vac/boost,oil temp,water temp,4WD split,voltage charge,Air inlet temp,exhaust gas temp and injector duty cycle.This unit can also be used as a monitor for DVD players or for a tv (with the adition of a tuner box)I have the loom section for this and all the wiring diagrams needed to fit.I have fitted them to various vehicles in the past and its not difficult to do.Selling price is $1500.This unit will fit directly on the dash of a 34 GT-T
[email protected]
https://www.sau.com.au/forums/topic/41240-r34-gtr-muti-function-display-unit/
This unit would wire into the loom I'm assuming. Do other cars for example a GT-T have sensors for these types of measurments? They aren't going to have 4WD split but what about Air inlet temp and exhaust gas temp? Are these sensors only on a GTR as I know the 34 GTR has a sensor on the cooler.
all the sensors on the GT-T will work.....i will supply the intercooler intake sensor with this display
You have to give a man a hard on just before he leaves work don't you.
How did you come accross this unit and does it interface with the standard gauges air feed etc?
Is the standard boost guage on the R34 GT-T pneumatic or electronic?
have you many of these?
i have 3 of these units,only one is a vspec(has exhaust temp function)I have the full vehicle schematics for 34 GTR so it shows you what wire does what.....you can power this unit up on the bench by simply adding positive and negative feeds.
its both...has a airline to a sensor then transfers the info by wire to the dash.....we intercept the signal and feed it into the MFD....
ylwgtr2 - know anyone who can fit one in melb? How much would it cost do you think?
*thinks of the wank factor*
heh
I guess try the place that you bought your car from.....If i can do it i guess they could
Any chance you would know what "extra" sensors that would be possibly needed for a r33 gtst??? This is a serious question. Thanks Rob
Rob.....all your sensors should work...if not i should have the sensors needed to get it working....This is a serious answer.Thanks Ylwgtr :P
Any questions please PM as we dont want to clutter the forsale section
Here's a good jap page on how to hook it up, babelfish it for japlish instructions, or get troy to translate it dfor ya :P
http://www.kcn.ne.jp/~oreteki/car/mfd_diy.htm
And here's a pic for the sceptics to show you it WILL work :D
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
