From what I understand all the claimed test booster do not boost testosterone they support the natural balance between test and estrogen. There is not artificial boosting at all. That ingredient macuna puriens helps with the balance. And if your test is high, lucky you because most of the 'normal range' levels sited by western medicine are too low. It has been proven that test from ancient non-westernized humans are close to double the level of westernized men. They also have non existent rates of heart disease, diabetes, obesity and hormonal issues we have. So I would not worry really because men with so called normal range test are less likely to create waves and a lot easier to control.... exactly what the government want.
fair enough, but I'm a female.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902501
Ooops forget about the latter rant then. Out of interest what is the ratio between test and estrogen.
I'd have to tell you that when I'm at home.
So I'm still slightly confused as to what is an appropriate supplement for me to take
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902652
Leesh.
Phenibut pure.
That Dorian Yates stuff is expensive repackaging, no points for guessing Mr Yates didn't get his huge size thanks to this stuff.
Don't think Dorian is a goal body shape for you ?
This is why I think the Yates powder is having a lend:
* It's not going to boost test (if it did it would be illegal).
* ZMA , called zinc tablets (when not being touted by muscle building supliment companies), is basically $6 for a bottle of 100 tablets from Cenovis, with the Zinc Magnesium & B vitamin ratios that work. IF you are deficient.
* Maca Puriens contains trace amounts of L-DOPA as it's claim to fame (so do ordinary broad beans), thats not a hormone balancer of any kind.
* GABA has a weak amount scientific evidence for it's effects, given it can't pass the blood brain barrier. So it's mechanism for efficacy is not known if it can work.
Phenibut can pass this barrier hence is evidenced as being effective and understanding of the mechanisim.
There is Phenibut in this stuff but, it's an undisclosed amount. That is the part that works.
Phenibut is about 3c to 12c a serve and works vs $2 - $4 a serve for the effective part.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903287
All the points above are valid however if you want to try an all in one sleep aid then I recommend this. Why? Because it actually does assist sleep. As with a lot of blends and also foods in general, the sum of the parts create different results than looking at the individual contents in isolation. For people not bothered to search for individual ingredients this is good to purchase. If you get results then search for the ingredients individually. And yes the claims are stupid as with any other body building supplement. $50 isn't a bad investment if it works, and it will work as it has for the 20 plus people I have recommended it to over the last 2 years.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903603
I understand. You are quite right that it would assist sleep (contains Phenibut). I think you have a good point as Phenibut isn't an easy suppliment to find.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903611
#@rev210
I'm looking at purchasing Phenibut from the Primaforce website; do you suggest the powder? There are tablets on there too but I don't think they're pure Phenibut, plus they have gelatin in them.
Just want to confirm the powder is what I should be getting before I purchase, thank you.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911130
#@rev210
I got it from ebay. from this place.
http://www.ebay.com.au/itm/Phenibut-100g-Pure-Nootropic-Go-out-have-fun-dont-drink-Wicked-Gear-/290935953856?pt=LH_DefaultDomain_15&hash=item43bd2259c0
Taste is like very strong grapefruit juice (acidic) in water. It's only $36 for 100g. Bargain.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911836
I tried ronnie colemans resurrect pm but I think I have issues with the tryptophan in it as it gives me anxiety attacks ( I already take tryptophan during the day ) I have tried gh blast which has GABA included and that seems to help me alot better. Let me know how that powder works l33sh as at about $90 a tub of gh blast it sends me broke rather quick
Edited by Kenna802
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6926070
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
