From what I understand all the claimed test booster do not boost testosterone they support the natural balance between test and estrogen. There is not artificial boosting at all. That ingredient macuna puriens helps with the balance. And if your test is high, lucky you because most of the 'normal range' levels sited by western medicine are too low. It has been proven that test from ancient non-westernized humans are close to double the level of westernized men. They also have non existent rates of heart disease, diabetes, obesity and hormonal issues we have. So I would not worry really because men with so called normal range test are less likely to create waves and a lot easier to control.... exactly what the government want.
fair enough, but I'm a female.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902501
Ooops forget about the latter rant then. Out of interest what is the ratio between test and estrogen.
I'd have to tell you that when I'm at home.
So I'm still slightly confused as to what is an appropriate supplement for me to take
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902652
Leesh.
Phenibut pure.
That Dorian Yates stuff is expensive repackaging, no points for guessing Mr Yates didn't get his huge size thanks to this stuff.
Don't think Dorian is a goal body shape for you ?
This is why I think the Yates powder is having a lend:
* It's not going to boost test (if it did it would be illegal).
* ZMA , called zinc tablets (when not being touted by muscle building supliment companies), is basically $6 for a bottle of 100 tablets from Cenovis, with the Zinc Magnesium & B vitamin ratios that work. IF you are deficient.
* Maca Puriens contains trace amounts of L-DOPA as it's claim to fame (so do ordinary broad beans), thats not a hormone balancer of any kind.
* GABA has a weak amount scientific evidence for it's effects, given it can't pass the blood brain barrier. So it's mechanism for efficacy is not known if it can work.
Phenibut can pass this barrier hence is evidenced as being effective and understanding of the mechanisim.
There is Phenibut in this stuff but, it's an undisclosed amount. That is the part that works.
Phenibut is about 3c to 12c a serve and works vs $2 - $4 a serve for the effective part.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903287
All the points above are valid however if you want to try an all in one sleep aid then I recommend this. Why? Because it actually does assist sleep. As with a lot of blends and also foods in general, the sum of the parts create different results than looking at the individual contents in isolation. For people not bothered to search for individual ingredients this is good to purchase. If you get results then search for the ingredients individually. And yes the claims are stupid as with any other body building supplement. $50 isn't a bad investment if it works, and it will work as it has for the 20 plus people I have recommended it to over the last 2 years.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903603
I understand. You are quite right that it would assist sleep (contains Phenibut). I think you have a good point as Phenibut isn't an easy suppliment to find.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903611
#@rev210
I'm looking at purchasing Phenibut from the Primaforce website; do you suggest the powder? There are tablets on there too but I don't think they're pure Phenibut, plus they have gelatin in them.
Just want to confirm the powder is what I should be getting before I purchase, thank you.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911130
#@rev210
I got it from ebay. from this place.
http://www.ebay.com.au/itm/Phenibut-100g-Pure-Nootropic-Go-out-have-fun-dont-drink-Wicked-Gear-/290935953856?pt=LH_DefaultDomain_15&hash=item43bd2259c0
Taste is like very strong grapefruit juice (acidic) in water. It's only $36 for 100g. Bargain.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911836
I tried ronnie colemans resurrect pm but I think I have issues with the tryptophan in it as it gives me anxiety attacks ( I already take tryptophan during the day ) I have tried gh blast which has GABA included and that seems to help me alot better. Let me know how that powder works l33sh as at about $90 a tub of gh blast it sends me broke rather quick
Edited by Kenna802
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6926070
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
