Since Sunday night I've slept a total of 4 hours, I'm going to the doctor this afternoon to get my melatonin levels checked and possibly something for tonight to induce sleep as I've had a couple of minor hallucinations.
The only change I've made recently is increasing my daily food intake, does anyone think this could be related to sleeping issues?
Don't know about the others, but pure phenibut is usually 500mg to start with, and increase from there if no effects are felt (takes a few hours to set in and can stay in your body for a day, so only increase the dose 24 hours later). Remember to have wash out periods, 4 days on 3 off etc. as the body can build tolerance fast in a matter of days/weeks and then you'll be taking grams of the stuff to get the same effects.
Have also read that addiction and withdrawal from long term use of phenibut are unpleasant, so it may be useful to do short term trials to keep yourself in check.
Hey guys/girls I got my GABA powder, phenibut and l-arginine powder and just wondering what I should use to get the right amount ?
To be honest I think start with gaba and arginine and see how you go. I think you would be surprised with the results. Phenibut will serve it's purpose if really needed but something to avoid if possible because of it's negative side effects with dependancy. Just a thought.
I would disagree strongly with the e-opinions on Phenibut about negative side effects and dependancy.
Also respectfully , that GABA or Arginine are actually effective in directly treating sleep function. Neither can pass the blood brain barrier to effect the brain. Not withstanding they might, they aren't anything near the effectiveness of Phenibut, for obvious reasons.
Arginine can help reduce cortisol but, the assumption would be you are defficient. It has a mild stimulation on HGH levels but, only if injected. Oral ingestion has no effect.
Phenibut is phenylated GABA and is able to pass the barrier.
Adding my own experience. Doesn't prove the science case for or against but, is consistant with the already established scientific data.
I have been taking it for some weeks now . And I have tested high dosages (upto 5gms) and suffered zero withdrawal or tollerance increases. It did casue me to laugh my ass off though. I have gone days without it recently with no ill effects. No suprises really.
Mmmmm science is amazing....especially when it tries to disprove things that have proven to work in REAL LIFE. Scientists or pharmacists with minimal real life experience should give no weight to research and white papers especially when real world experiences differ. That's ok. They will learn the limitations of science eventually.
All I know is from my personal experiences are that being on meds for 10 years ( I was wrong in my post about 6 or 8 years whatever ) is that all it did was turn me into a fat slob who had no ambition or drive. ( I forced myself to the gym 4 times a week and did not lose any weight or gain any muscle ) I also still had trouble sleeping and also lost the fight or flight response and just didn't care in general. Now I know people will say that I was on the wrong meds etc but I had tried about 5 different types during that stage.
In regards to sleep I was prescribed endep as well as various aids and all I can say was that while I did sleep for about 4 hours I than was restless for the remainder of the evening and woke up feeling more exhausted than when I went to bed. The couple of natural sleep aids I have found have allowed me the best nights sleep I have ever had but the down side is the body gets used to it very quickly so I have to sacrifice some nights so I can get sleep others. Not perfect I know but better than the alternative.
I'm not for or against medicines I just believe if they work than that's great but if not than there is an alternative.
Hey l33sh. Hope you are feeling better.
Just to add for the first time I am prescription drugs and trying natural supplements. While I still am a bit up and down ( anxiety plays a big part ) I am actually fitter and more with it than I ever have been. A mate saw me today and asked what I have been doing cause I look so good. ( no homo lol ) It' feels good that people notice these things.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
