Since Sunday night I've slept a total of 4 hours, I'm going to the doctor this afternoon to get my melatonin levels checked and possibly something for tonight to induce sleep as I've had a couple of minor hallucinations.
The only change I've made recently is increasing my daily food intake, does anyone think this could be related to sleeping issues?
Don't know about the others, but pure phenibut is usually 500mg to start with, and increase from there if no effects are felt (takes a few hours to set in and can stay in your body for a day, so only increase the dose 24 hours later). Remember to have wash out periods, 4 days on 3 off etc. as the body can build tolerance fast in a matter of days/weeks and then you'll be taking grams of the stuff to get the same effects.
Have also read that addiction and withdrawal from long term use of phenibut are unpleasant, so it may be useful to do short term trials to keep yourself in check.
Hey guys/girls I got my GABA powder, phenibut and l-arginine powder and just wondering what I should use to get the right amount ?
To be honest I think start with gaba and arginine and see how you go. I think you would be surprised with the results. Phenibut will serve it's purpose if really needed but something to avoid if possible because of it's negative side effects with dependancy. Just a thought.
I would disagree strongly with the e-opinions on Phenibut about negative side effects and dependancy.
Also respectfully , that GABA or Arginine are actually effective in directly treating sleep function. Neither can pass the blood brain barrier to effect the brain. Not withstanding they might, they aren't anything near the effectiveness of Phenibut, for obvious reasons.
Arginine can help reduce cortisol but, the assumption would be you are defficient. It has a mild stimulation on HGH levels but, only if injected. Oral ingestion has no effect.
Phenibut is phenylated GABA and is able to pass the barrier.
Adding my own experience. Doesn't prove the science case for or against but, is consistant with the already established scientific data.
I have been taking it for some weeks now . And I have tested high dosages (upto 5gms) and suffered zero withdrawal or tollerance increases. It did casue me to laugh my ass off though. I have gone days without it recently with no ill effects. No suprises really.
Mmmmm science is amazing....especially when it tries to disprove things that have proven to work in REAL LIFE. Scientists or pharmacists with minimal real life experience should give no weight to research and white papers especially when real world experiences differ. That's ok. They will learn the limitations of science eventually.
All I know is from my personal experiences are that being on meds for 10 years ( I was wrong in my post about 6 or 8 years whatever ) is that all it did was turn me into a fat slob who had no ambition or drive. ( I forced myself to the gym 4 times a week and did not lose any weight or gain any muscle ) I also still had trouble sleeping and also lost the fight or flight response and just didn't care in general. Now I know people will say that I was on the wrong meds etc but I had tried about 5 different types during that stage.
In regards to sleep I was prescribed endep as well as various aids and all I can say was that while I did sleep for about 4 hours I than was restless for the remainder of the evening and woke up feeling more exhausted than when I went to bed. The couple of natural sleep aids I have found have allowed me the best nights sleep I have ever had but the down side is the body gets used to it very quickly so I have to sacrifice some nights so I can get sleep others. Not perfect I know but better than the alternative.
I'm not for or against medicines I just believe if they work than that's great but if not than there is an alternative.
Hey l33sh. Hope you are feeling better.
Just to add for the first time I am prescription drugs and trying natural supplements. While I still am a bit up and down ( anxiety plays a big part ) I am actually fitter and more with it than I ever have been. A mate saw me today and asked what I have been doing cause I look so good. ( no homo lol ) It' feels good that people notice these things.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
