hey all,
i've decided to sell some parts from my shed, these were meant for my s13, but am selling due to wanting a motor bike to get my licence on.
the engine RB25DET is from a 1996 series 2 r33, i bought a complete stat written off car from the auctions (rear end damage).
so i have had the engine running and driving, it was a very clean car before the accident, i had a mechanic mate check it all out for me and theres no problems with it. it has 120xxxklms on it, (i have paper work from auction that can prove k's) to sum it up, it runs smooth, revs nice, comes on boost without a problem, the only thing i was going to do to it before putting it in my silvia was timing belt and water pump.
it comes as pulled from car, includes turbo, manifolds, wiring loom (un cut), afm ecu. etc etc.
im asking $1600 ono,
the gearbox (S2 rb25det 5speed manual box) is from the same car, when i drove the car up the street there were no problems with it,
shifted smoothly into every gear.
asking $1500ono
i also have a pair of front guards from the S2 r33, white in colour, no damage but they may have slight scuff marks from being in storage,
asking $200 pair
pair of r32 front guards, drivers side is in good condition, passenger side had a large dent in it which has been hit back out, will need repair and paint but is still useable.
asking $100 pair.
i will list other parts up as i come across them, (mostly interior and engine bay parts, nothing exciting)
all this stuff has to go, will take any reasonable offer,
parts are located in woodville nsw 2321, (40 mins from newcastle, 20mins from the end of the freeway)
i work in lambton so i can meet people around that area to drop any parts off.
if you need pics text me 0449669476 and i'll reply with pics.
Thanks,
Brock
pm sent mate,
also for sale are
r33 series 2 door trims and rear quater trims,
excellent condition, $150ono. the lot.
r32 dash, bubble in the usual spot and missing centre and passenger side air vent, $50
r32 standard platsic rear bar, black in colour, will probably need painting as its been in the shed for years, $20
i'll upload some pics tomorrow night mate,
more for sale,
2x pairs of r32 side/door mirrors, black, might need paint, $100 ono per pair
r33 manual tail shaft $150
r32 bootlid in black has been repainted, needs polish, has holes for wing, $80
r32 pair of tail lights, black, good cond, $50 pair
r32 centre console good cond, $20
r32 doors, black but been half sander down, include glass, motor etc, $200 ono pair
r32 rb20det front cross member, $120 ono
r32 rear cradle complete minus diff and rotors/ calipers, $100
r32 rb20det radiator-manual, $50
also have the boot, door and window seals/rubbers for sale, let me know what you need and i'll give you a price
Engine sold
still got everything else there,
Also got a '92 r32 shell for sale, is rolling, no panels, no brakes/diff etc,
will come with all the interior i still have left from it.
few things left in engine bay, has rust around rear window, message me if you want to see some pics
not sure what its worth, say $1000 negotiable, send me some offers, perfect for track car, or it can be re-registered.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
