Selling my Kando TD06-20G
It was originally off a RB20 R32, it made 210kw on 1bar, full boost was at 5500rpm.
This would be best suited for an RB25, unless you don't mind a bit of lag :P
Water and oil cooled
I'm guessing it's either a 10 or 12cm turbine (probably 12cm).
No shaft play, good condition.
This is originally an internal gate turbo, but has been modded for external gate.
Comes with a 2.5 inch cover, which is perfect for OEM sized intakes and will look factory.
T3 flange so it'll bolt up to RB20/RB25 manifold too.
Should make around 250ishkw on a 25.
Price: $450 ono
Located in Liverpool region
Will ship at buyers expense.
PM me!
Adam.
Edited by Run-It-Hard
https://www.sau.com.au/forums/topic/414103-kando-td06h-20g-turbo/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
