As Sin mentioned we need something to happen pre Christmas as numbers have been lacking etc.
Throw some dates up
Throw some ideas up
Let's get something happening! There are a few people who have joined up but not been to many things so guys let's make an effort.
B-rice I know your down
Rob I'm looking at you to buddy
https://www.sau.com.au/forums/topic/414232-christmas-catch-up/
  • Replies 146
Saturday the 15th of December afternoon/evening would be good.
Somewhere round the lake making it central to all
Chicken, salad and softdrinks/harddrinks
Frisbee, footy, Volleyball etc....
Family friendly if you got kids (PG recomended)
+1's welcome
Just one thought
+1's welcome
Just one thought
Weekend of the 15th is the only weekend I have free all month, and even then if the opportunity for a coast trip comes up I'm afraid I'm giving preference to that....
A big BBQ would be good, somewhere easy where we could all meet up! either way put me down and i might be +1.... If i can ever convince the partner to come to a car thing! Nick if you are going get Sky to bully her into coming!
I dont agree to bullying lol but we can hog tie her and put her in the boot! lol
Ok so think of a good spot.
Looking for BBQ's for those who want too, Water cause it's nice, big grass area for mucking about, cars not too far away for security, central.
4 or 5 in the arvo allows christmas shopping, peeps who may work, cooler in the afternoons, domestics etc...
Gaffa Tape or Zip ties - got both :ph34r:
We need people to be 100% otherwise it turns into just 1 or 2 people
sitting there with 400 sausages...that shit aint fun guys.
I bailed on the last one because I was a newb and didnt know anyone
But that was stupid because everyone is really welcoming
Which is why shit should be BYO. Never rely on other people to hold to what they say. Their problem if they can't be self-sufficient anyway haha
After looking into it, I'm free on the 2nd, 9th, 15th, 16th, and 23rd.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
