Hi,
I have just upgraded injectors (nothing rly else that would affect anything) on my R34 GTT. I have nistune and so i changed the k constant by going through the injector resize option and changed from 725cc to 1000cc.
This brought the k constant down from like 394 to 285. Problem is my air fuel gauge shows about 20 on the gauge and it runs pretty choppy. If i move the k constant up closer back to 394 originally the AFRs drop down back to closer to 14.7.
But if i rev it just a tiny bit it jumps up again.
Any suggestion would be appreciative! Just trying to get the car able to be moved to the tuners 350km away.
It already had an existing tune and ran no problem.
Injector latency is different even between same brand. An example is this pair (Denso made injectors). Sard 700cc 0.65msec, Sard 800cc 0.75msec.. so you can imagine the latency difference between 725cc and 1000cc.
Bring you min injector on time up a little - they are probably be operated outside the non linear range of the injector... Unfortunately it is not an exact science... Especially when your not taking into account latency.
Edited by rob82
Hey guys yeah you were right thanks jacked the latency to 1030. Now its idling perfect at ~ 14.7 AFR and rest of the rev range looks good. Might read a bit more instructions next time ;) There wont be any damages having 20AFR on idle ? Also not having narrowband plugged in is also okay on a 350km trip ?
Narrowband sensors get damaged when they're not powered as the heater can't burn off deposits. It sounds like you're using Nistune, there's are afew ways to ignore O2 feedback, one of them is to set the minimum engine temperature which the ECU will accept O2 feedback (defaults at 30C) to something high 200C where the engine has no chance of getting that hot, this way they will at least be powered.
I have my wideband in its place at the moment, so its not connected at all or screwed inside the dump. I prefer to keep the wideband so i can monitor AFRs on the way there, also just read that i can solder some wires to the ecu to simulatre narrowband signal :O. Its MTXL Innovate one. Or since the AFRs are okay i can just plug in the narrowband so cruise is okay and hope not issues.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
