Bernie ecclestone had been in talks with officials in an attempt to save the race but told German magazine Spiegel that: "After due consideration of their proposal we believe it is regrettably not financially acceptable, so we have terminated our negotiations."
However, while Nurburgring's chances of hosting the race are looking slim, Hockenheim may be asked to fill the void.
"I am doing my best to make sure we have an event in Germany," Ecclestone told theAssociated Press, "but, at the moment, I can't say whether it will be Hockenheim or Nurburgring."
In an additional twist, Pitpass have reported that Jorg Linder and Kai Richter, two businessmen involved with the Nurburgring, are suing the circuit's boss, Karl-Josef Schmidt. The duo allege that Schmidt damaged the negotiations with Ecclestone.
http://www.planetf1....saga-rumbles-on
Ferrari have confirmed that their 2013 challenger will be called the F138.
The name is derived from the current year, 2013, and the number of cylinders in the new model, 8.
The car is the 59th Ferrari single-seater to do battle in F1 and will be launched on Friday.
http://www.planetf1....-named-the-F138
Bernie Ecclestone says that Scorpion Racing will not feature on the 2013 grid despite a late attempt by the team to register.
"I've spoken to them and told them to get in touch with the FIA and ask for an entry," said the Briton.
"They want to buy all the bits from HRT, then form a company and ask for an entry, but I personally don't think it will happen. It's all a bit too late. Maybe they could do it for next year."
http://www.planetf1....-Racing-in-2013
McLaren took the covers off a "completely different" MP4-28 at their Technology Centre on Thursday.
Similar in many other ways to its predecessor, Button says he is eager to get behind the wheel for the first time next Tuesday at Jerez.
"The winter has been long but enjoyable," said the Brit.
"But a Formula One driver wants to get back in a car and feel the speed again.
"It's been an exciting few weeks, building the car and finally seeing it as one late last night."
"It may look like last year's car, but under the skin it's completely different.
"That's why it's so exciting. They've changed enough to make a difference.
"You go into the season aiming to win the World Championship and thats's what we are doing."
http://www.planetf1....ifferent-MP4-28
it looks like they tried to fix the elements of the car that they had problems with last year and evolve what worked well, like that front wing it's completely different to last years one.
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
