Hey guys, have any of you got a photo of your car with the coby extractors fitted or any other type for that matter. I'm fitting a camber kit next week and contemplating whether or not to lower it at the same time or leave it stock to allow for the extractors if they hang low. I need to be able to get up my steep driveway
ive only seen pics of them , and i ,m not real keen on the design , no 6 pipe looks like its 2nd bend is too tight also same on no 1 pipe . they are not tuned length cos the front pipes look a lot longer than the rear ones . the primaries are 1 1/2 ", looking at the size of the rb25de ports they should be 1 5/8" primaries . i,ve had a quote from a business called GONZO PIPES , he makes the best , does lots of race cars , but will cost around $900 and that was with a tuned length megaphone for racing ... i got pics of the coby extractors if you want
If you've got a pic of the extractors fitted that would be great, otherwise i've seen a pic of them in a catalogue. I may be wrong but they do look a bit dodgey. Wrapping them in exhaust wrap and the red paint flaking off doesn't grab me either. I'm in Melbourne, are there any good exhaust places that would do a good job for a reasonable price?
Hi Guys,
Yes the Coby extractors are "dodgy", but they are good value for money.
They're cheap - not a lot of engineering could have gone into them.
However, we know they smooth the power and torque curves of the engine, improving drivability. The engine feels a LOT more torquey at lower revs and pulls well from about 2500rpm.
For me it was so noticable that on roads I drive regularly I could use 5th where before I had to use 4th.
So while they are definitely not optimal from a performance point of view (as dondesoto showed us), I reckon they do a great job for the money.
Cheers,
Greg
Thanks for that greg, i think i will just go with the coby's, so you think ordering them from partsco is the way to go? How long does it take and what do you recommend as to fitting them re the paint flaking off etc. Shall i strip the paint beforehand? Have you lowered you car or dos it still contain the stock suspension. It just worries me a bit if they're goign to be dragging on the road after lowering! Or going over a speed hump. I have lots of speed humps where i live :)
Cheers!
PartsCo are the way to go. You pay New Zealand price, so save a bit of money as well. If you can be bothered, I recommend stripping the paint and then either wrapping them in exhaust wrap or painting them with a suitable high temperature paint.
My car is stock ride height and I've never had a problem with scraping. I'll take a pic to show you how low they hang, if you'd like!
Cheers
Greg
2500$ for extractors only!?!?! $2K will get you a full(dump,front,hiflo cat,cat back and muffler) exhaust. not even 2500 for a full NA exhaust sounds believable, unless you gain like 30rwkw from the extractors alone. not saying i dont believe you Greg but that price is outrageous
although im a fan of buying 'proper japanese aftermarket gear' such as trust, hks etc due to them having alot of R and D, if a quality product cannot be obtained then custom is the way to go. custom tuned length non restrictive extractors could see as much gain as Fujitsubo extractors.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
