Just had my V up-rev tuned, 227.3 rwhp (169 rwkw) before tune 245.1 rwhp (183 rwkw) after. Pulls alot harder especially mid range, revs to 7000rpm and still has more go but a bit cautious to go any further. The up-rev tune was done by PZP in Perth. $550 :thumbsup:
  • Replies 96
Posted Images
So worth it hey. Couldnt believe the improvement in torque and response.
i notice it most in mid range, from 80k's up it seems to just get stronger. 2nd gear 110km/h @7000rpm and still had some stick....but was cautious to go any harder. Fully recommend for any one interested in squeezing all they can from a N/A engine :yes:
Hey Gerard, what mods have you got?
Hey xj265 Z tube, K&N high flow filter in stock air box, MD 5/16 plennum spacer, throttle body spacer, Y pipe stock cat back, transgo shift kit, Lovells springs, Kinetix full camber/traction kit and now Up-rev tune :D
Thats complicated! First run was 166rwkw without a tune.
My ECU didn't seem to like Uprev; it had a Master rom version they hadn't seen before so its with Uprev to get it sorted.
Hopefully will be sorted before the new year :)
  • 3 weeks later...
I'm stoked! This is with the cheap and nasty compliance air filter and cats (that are mismatched).
Mods to come: replace awful y-pipe/cats, new air filter.
Current mods: Motodyne 5/16 spacer, Rev up air box, stillen z-tube, JIC Magic Spartan DE Catback, chinese y-pipe
    • This thread keps giving with the OMG!
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
