PRICE DROP
RB25DE Non Turbo Only Parts
  • Fuel Rail, Regulator and Injectors - $90
  • Exhaust Manifold and heat shield - $35
  • Exhaust Front Pipe and heat shields - $35
  • Air Box - $25
RB25DET Turbo or RB25DE Non Turbo Parts
These parts are suitable for either turbo or non turbo RB25 motors. I'm pretty sure all of them are interchangeable. If some aren't please let me know.
  • RB25DE VCT Cylinder Head - This is the non-turbo variant which has lumper cams than the DET version and was going to be used for an RB30 conversion. I've spent $300 (I have receipts) on it to have it disassembled, cleaned, warp/crack/pressure tested and combustion chambers cc'd to get it ready to be ported and polished etc - $800
  • Alternator and Bracket - $90
  • Inlet Runners from head to plenum good for port matching to head(no water pipes) - $45
  • Manual Gearbox Starter Motor (might be usable on auto) - $60
  • Power Steering Unit (a bolt mounting hole has a crack and the pulley wheel is bent) $40
  • Turbo Oil Supply Line with heat shielding - $25
  • Coil Packs (6x), Wiring/Plugs and Alloy Brackets - $250
  • Water Pump Pulley Wheel - $15
  • Radiator Fan Clutch Unit - $30
  • R33 GTST Steering wheel Non Airbag - $75
Other Parts
  • Set of 6 RB30 Rods - $95
  • RB25DE Non Turbo Bottom End (crank, pistons, rods, clutch/flywheel) - Was looking for $350 now want $225
  • RB25DET Bottom End (crank, rods, sump, oil pickup, oil pump, water pump). Pistons are damaged from detonation (leaned out injector i think), so would suit a rebuild. Good condition otherwise - Was looking for $500-550 now want $350
  • Take Both bottom ends for $525
PRICE DROP
I'm happy to post any of the bits you need at the buyers expense. Or you can drop in and collect parts from my place. I'm in Melbourne, inner east. I would prefer the buyer of the engines to collect them as the cost of shipping them interstate would be about $100 to Sydney, around $160 to Brisbane and $100 to Adelaide so not really worth it. These are my shipping estimates from previously shipping an engine to Sydney.
Here is a link to a zipfile with the pics in it (no pictures of cylinder head).
Email me at [email protected] or send a PM
Cheers,
Andrew
https://www.sau.com.au/forums/topic/41476-assorted-r33rb25-parts/
[*]Alternator and Bracket - $125
[*]Radiator Fan Clutch Unit - $45
Cheers,
Andrew
hi andrew im from SAU anyway the fan clutch unit, is that the fan that bolds to the front of the radiator? u got pic? my email is [email protected]
it's the bit that goes onto the water pump that holds the radiator fan. The silver bit that looks like it's got little heatsink fins on it. It's the clutch unit that keeps the radiator fan spinning at a constant speed.
ok, tomorrow i will break out the digi camera and post pictures of all requested parts!
Edit: tomorrow (saturday 29th may) i promise will be picture day. I got my car back on the road so i've got some time. I'll take photo's of all parts on the list, and post them up. What's the easiest way to post them? how do you do the thumbnail posts?
Andrew
  • 3 weeks later...
Ok guys, sorry for such a long delay. Here are some photo's of some of the parts. If there are any that you want that aren't here let me know and i'll take a snap.
calemb: that's a bit low, $110 and it's yours.
Here is a link to a zipfile with the pics in it.
Also how do you do the little thumbnail posts with all the pictures in it?
Cheers,
Andrew
what does the VVT switch wire look like (colour and location)? i presume it does as the head that it was connected to has VVT. Injectors are standard RB25DE injectors. I presume they will be the same as RB25DET but just flow a bit less, so side feeds.
Cheers,
Andrew
  • 4 weeks later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
