Gday,
All prices negotiable. Pick up preferred from Beaudesert Qld, but willing to post if needed. All parts are used and from c34 s1, s2 and 260rs. I work long hours so don't expect an instant reply but I'll do my best.
Thanks for looking.
post-58649-0-32984300-1355125119_thumb.jpg $100 - Dash mat
post-58649-0-90000500-1355125127_thumb.jpg $100 - Complete genuine floor mat, drivers worn.
post-58649-0-65876600-1355125131_thumb.jpg $150
post-58649-0-25030400-1355125262_thumb.jpg $100
post-58649-0-85524700-1355125025_thumb.jpg $20 - For rb25det - not direct fit though
post-58649-0-29956300-1355125021_thumb.jpg $5
post-58649-0-24935400-1355125033_thumb.jpg $20 - S1 woodgrain
post-58649-0-55925900-1355125036_thumb.jpg $10
post-58649-0-87990900-1355125042_thumb.jpg $150
post-58649-0-18872000-1355125053_thumb.jpg $100 - HICAS lock
post-58649-0-08655900-1355125061_thumb.jpg $20
post-58649-0-48774400-1355125067_thumb.jpg $20
post-58649-0-02476000-1355125105_thumb.jpg $150 - Brembo rotors (machine recommended), nismo rear/ compliance front pads with decent meat
post-58649-0-83845400-1355125108_thumb.jpg $10
post-58649-0-69370500-1355125112_thumb.jpg $20 - Top and bottom rad hoses. red silicon (photo is bad) off an rb26 prob fit rb25?
post-58649-0-93961800-1355125133_thumb.jpg $50 - rb26, where running 360+ hp fine when removed
post-58649-0-14944000-1355125222_thumb.jpg $50 - Walbro gss 342, only used for 5000km
post-58649-0-77815100-1355125229_thumb.jpg $5
post-58649-0-14300500-1355125232_thumb.jpg $5
post-58649-0-16237100-1355125239_thumb.jpg $20
post-58649-0-36344300-1355125244_thumb.jpg $20
post-58649-0-38855900-1355125249_thumb.jpg $5 - hks oil filler cap
post-58649-0-66901200-1355125259_thumb.jpg $100
https://www.sau.com.au/forums/topic/415320-some-random-c34-crap/
what size are the rear rotors?
and is the boost controller electronic ( i guessing not by the looks of it ) and if so dose it work all good? and so u have all the bits?
Edited by whitenight27
Rotors are the standard r33 gtr brembos
Rears: 300mm
Fronts: 324mm
Dash mat SOLD
Boost controller SOLD
Oil cap SOLD
Console tray SOLD
Coil packs SOLD PENDING PAYMENT
Silicon Radiator Hoses SOLD PENDING PAYMENT
Woodgrain center console & stereo surround SOLD PENDING PAYMENT
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
