Yeah mate it's disappointing but I guess it's part of racing!
I'm not sure if I should pull the engine and leave the box in or box out leave engine in or both out .
I got a awesome 1.6 60" best launch to date,
Just drop box off the back man its quite easy. Good 60" none the less.
I ran 12.5 @121 2.25.
back to the drawing board. :yes:
aw thats terrible man. That was me there man sorry I didn't check this thread out there xd.
Howd everyone go
Forgot my shoes and had to walk around in work boots... I looked ridiculas lol
First time at willow bank 2nite and have 2 say what an awesome way 2 spend a wed arvo!!! Might even run the gtr on it the next nite we're out.... Good show lads!!!!
Is yours the blue GTR rolling on bbs rims?
Triple post stupid phone
Edited by Captain Natro
cool triple post!!
his is the blue LM...sexy car, let us know when you decide to run it. i wanna be there! :)
You know for the post count lol, but yer man it is... I saw the SAU sticker so assumed he'd be on here at some point
It sure is mate.... Only reason i went down there 2nite is i seen this thread and said i go for a spin and check it out!!!!
Love the car man, literally in my top three best looking 33 gtrs I've ever seen :thumbsup:
And yer it's usually a pretty good turnout, tonight was probley a little bit less then usual but I get the idea
I'll be heading out to spectate this one tomorrow...
*Gates open 5.30
*racing starts 6
*$45 to race (but admits two people)
*will need a minimum of long sleeves long pants approved helmet and closed footwear
*spectating $20...
If you think you spot me come say hi :ninja:
*Gates open 5.30
*racing starts 6
*spectating $20...
nice.
Sydney is 50 to race.
that's the driver only.
any and all passengers have to pay 20 entry.
