My R33 GTR's stock exhaust cam shaft is giving me 10 degree varients in ignition timing.
Mr nissan wants almost $700 odd for a exhaust cam shaft, Tomei Poncam's can be had for a little more and then at least i know both are new.
I have heard different things re power shifting to more of a top end car, It will be daily/street driven car.
Tomei make two different sets of cam's, Type A and B. I assume type A are similar to stock?
Is it worth sticking OEM or going after market?
Also while im posting, I need some front pipes. Any recommendation's on which ones and where to get them ?
I got my Tomei Type B's for $638 delivered so I'd go that way for sure.
I'm told the Poncams will make improvements low to mid rather than top end which is what I preferred.
Personally I think you're mad if you don't upgrade if it's similar in price.
Unless fuel consumption is of concern...
If you go tomei you will benefit most with a re tune..
Really depends on your current set up.. If its only mild I'd stick with the stockers
I'm sure some one has a spare cam laying around they could sell u
How is it giving you 10 degree variants? Is the drive spline for the Cas worn?
Sounds like the Cas is at fault?
The cas is throwing the ignition timing around due to it moving, but i believe the splines on the cas itself are fine.
The cam shaft drive is worn.
Also mods to the car;
Garrett -7's
Apexi PowerFC
Tomei Adjustable cam gears
Reco Head
Ganador catback exhaust
hiflow cat
pods
everything else is stock
After doing the head gasket and putting it all backtogether, it is at the tuners and the above was the diagnosis. Car was pulling 250-280rwkw on 15psi boost I was told, but not stable due to the cas messing with the ignition timing.
Just don't want it to be super revvy when its my daily/street car.
Edited by Booki
What timing belt?
Gates belts are known to get certain harmonics and can affect timing to a degree, but not 10degrees!!
Guess in you case the drive is worn then...
Nissan timing belt.
Yep drive is defs warn, I trust my tuner ;)
Just trying to decide if its worth going pon cam's or trying to find a used camshaft, that and some front pipes..
I would remove Cas and bracket, fit Cas and see how much movement is in the shaft.
10 degrees is more than 1 tooth of the timing belt
Edited by t_revz
Don't have the car at the moment so can't do any check's. Tuner is reputable and knows his stuff, and did warn me when i got the reco head back but was a "wait and see" sorta thing.
Pretty much need to know will going poncam's give me more bottom end or top?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
