Washing the Micra this eve after driving it from Point Hut road all through the Cotter area. (wow some mad changes have gone down since I last went through there)
Skyline wash tomorrow.
Got the dremel out and put the n1 vents in today.
The Nissan ones are lovely, nice paint job on them already, and they just clip in if you make the hole right.
Reminds me why i like Japanese made stuff.
Washed her.
Also went and picked paint up to do the front bar of the Foz and was going to spray it today.
But after finishing washing the GTR I cant be bothered. I will do it tomorrow avo.
How many cans did you get? I always seem to under estimate :/ Did you get it from Capital?
Did some more wheel cleanings. *sigh* still needs more attention.
Filled up @ $1.70.9 / Litre :O
Rear ended a Holden Cruise with no evidence of impact other than a chicks name, phone number and a memory of cleavage. :D
Too late to wash the Liner now... Must do in the morning.
Tried to fit the greddy oil cooler to the 34 designed to go in front of the radiator however my big ol' front mount appears to be in the way so I think I'll have to fab up some mounts and put it in the drivers side of the front bar.
Also used my car to rip a tree stump out of the ground.
Probably the most useful thing my car has done since I bought it.
How'd it turn out Eric ?
Likely will wash/polish car after yesterdays run.
Picked up 2 minor chips in the windscreen, from oncoming cars yesterday, so will try polish them out with some stuff I have.
Then I think a good movie and some munchies this afternoon :D
Any recomendations ?
Grammar
Richard, I can recommend pork belly.
I already know pork belly Richard intimately. Thanks for the referral tho - LOL :thumbsup:
It turned out pretty good. Will look much better once I blend the edges out. Taking for inspection tomorrow, then register....then sell!
I can reccommend pork belly Richard. LOL
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
