yeah well aware of that! =) just confirming that i can actually stick with what i am using.
I know different materials require different coolant to avoid corrosion. blah blah blah.. :)
just not sure if stock one=steel, and new china one=aluminium , thus different coolant needed.
If you do wish to change types (clolour) then have it professionally pressure flushed first.
This^^^
Stock is Brass I believe. The guys at Gibbs in Belco did mine (Natrad) and put in the coolant they deemed appropriate.
They also did a check for stray current to avoid Electrolysis eating away at my Aluminiums.
I had green before with stock Radiator (which was leaking) and Now I have red. It's pretty.
I use Tectaloy 100 which is green and pre-mixed. Also did a fair bit of research before selecting this one. It was between the Nulon and Tectaloy.
With the Alloy rad etc... I use green. No brass monkeys in my system - Tee Hee.
Nissan are now using Blue - FTW
Some are just died because it differentiates between GM, Toyota, Europee'n and US cars.
There is Red, Green, Orange, Yellow, Brown and now Blue.
They used to colour them for a reason. 3 different types - Oats, Hoats and another one.
Now it's all just pretty *rainbow*
Put the Foz in for rego inspection. Failed.....fog lights not working!
Checked all fuses just now and they are all fine. Checked the connectors to the actual fog light switch and one fell off quite easily, hoping that is what the issue is.
I couldnt get it back on. Have to pull bottom half of dash off to get to ot and cant be bothered tonight. will do it after work tomorrow.
Passed my rego inspection check up this morning! Woot!! :woot: After a decent sized list of small things to fix up:
  • headlight aim
  • atmospheric blow off valve
  • boost gauge within head impact zone
  • pod filter loose
  • manual boost controller/bleed valve
  • secure thermo fan
  • right side handbrake didnt work
  • wheels too wide
Big thanks to Rob for lending me some rims to get through the inspection, and a photo of them on the car was requested ;)
YAY! its always good to be allowed to drive on the road..
So are you not allowed to have manual boost controller/bleed valve in ACT? Is SA them same?
I'm about to install one soon, and moving to Adelaide shortly after, do i need to remove it before changing to SA rego?
Yeah im not 100% sure on the subject but this is what I think sounds about right from doing a lot of research. If you want to control the boost it has to be done from inside the cabin, but you cant have any air, fluid or gas (apart from air vents) passing through the firewall.. So to stop all the smart arses placing their bleed valve inside the cabin haha, and I think this is Australia wide. Someone feel free to correct me as im not 100% sure..
If you do install it I would just change it back to stock for the inspection. Only a 5 minute job once you know what you're doing.
Not a Pulsar has a pretty good setup, could probably talk to him about how he controls his boost.
Edited by dontyellpl0x
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
