Looks good :thumbsup:
Yep - change the colour of the fog light surround to Black = win
Last night went round to Robs to pick up a sedan pair of foggies I purchased as I prefer these over the normal coupe ones. While I was there we also slapped on a sedan grill just for shits and giggles to see how it looked over my m spec grill. And I think I actually prefer the sedan stuff... Maybe I should have just bought a sedan.. :/
Anyway, foggies installed this morning. Think it looks much nicer this way :D
I'm in.
and BTW why didn't you flaming mongrels let me know you were out drivin huh ?
I was actually sitting at Pine Island after my drive when I posted that. Thought about calling you but didn't want to disturb your secret cross dressing time. :rofl:
Dang - and you look so good in fishnets. Dude !
Should of buddy. I have bourbons and a spare room (no lock on the door either ;) )
PS: Girl Friend is comming over :3some: - Sweet ! She has 2 single sisters !!!!!
(That's me in the middle)
No crossing the streams :starwars:
Bahahha
One more edit: I'm making Salt and Pepper calamari and a Thai curry prawns on rice for dinner :D
Aussie prawns and NZ Calamari - FRESH !
Thanks mate, but I wanted to get back home. The Mrs EX has been moving stuff out all day. (hence me going for a long, fun, solitary drive)
and she just drove away this second so yeah... :(
PARTY AT ROB'S HOUSE ANYONE???!!! :woot:
:banana::bunny::3some::bunny::banana:
That's good news mate. Seriously - GOOD MOVE :thumbsup:
Hope nothing of yours just drove away too ... besides cum stains.....sowwy! was funny in my head!
Can't come party - have Orgy to orgynise :P
edit: You need anything just give me a call
2nd edit: seing your single again, get rid of the Penal in your sig! attracts the wrong sort, know wat I mean :nyaanyaa:
I remember why i havent changed a clutch for 15 years.... bastard of a thing.
Finally worked out the twist to get the box back on and now i realize i didnt push the aligning tool all the way in and missed the crank splines.
>_<
So back out with the box..... loosen the clutch off gradually and evenly, align properly, and back together all over again.
First times a bitch, but im learning the tricks to this car.
Just plumbing.
A cock is a valve.
Ballcock= ballvalve.
Lots of cocks in plumbing.
Tomorrow is gonna be Cockstop! Just a heads up. LOL
Very sensitive
(and slightly homophobic I'd say from my comments)
Sensitive I can relate to my fellow Cancerian.
Crossdressing Homophobe? You need a Shrink!
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
