Cheap ass brake bleeding kit arrived today, also found out my pressure washer wont fit any attatchments.
The bastards changed the fittings and dont have adaptors.
Bosch used to be German, now its Chinese.
:down:
:down:
same with my pressure sprayer, tho with it being a karcher (how ever you spell it) fitting are heaps pricy :( think ill just use the big diesel powered one at work
Don't use my pressure washer on the car. Gentle is the way to go :thumbsup:
I was going to use it on the the gearbox near the rear main seal, rocker covers were leaking a while ago and its really built up! id never touch the car with one, don't want my paint to chip any more :)
Back in the day when I was a Detailer, I saw someone accidentally blast half the C sticker off the back of a CLUBSPORT. :O
No it wasn't me.
Yes I did laugh.
I washed my bike and car yesterday as it was just a nice sunny day and now its all dirty again as you can see all the dust on a black paint easily :(
Took my car out for a drive today went and saw john, he thought me how to use a button clutch and also found out that left engine mount is broken so now i got my next weekend job lined up
Yep! Polished my car at 6 pm today. Just went out to get my iPod out of it. Had a look and it's dirty again, takes the joy out of owning a black car...
Edited by ..::R33GTS-T::..
i use it on the soft spray
However....
I would like it to be strong enough to just strip all my shtty paint away.
the big diesel washer at your work will do that....... :laugh:
Found a solution to the washer problem, need to make a small fitting with a very fat thread on one end.
Edited by D.I.Y. Mik
Hmmm... that would be nice. Unfortunately my paint is....... um, it would be like polishing a turd.
So its time to change that.
This will help make painting easier:
All made from junk behind the shed. Just need a double sink connector from Bunnings and its hooked up.
Its not hoarding if you eventually use it.
  • Like 2
However....
I am almost sure it you put it on the sharp stream it will get it back to bear metal ! its insane
the sink looks awesome :)
Bill, I think I've said this before but...I WANT YOUR WHEELS! Very Tasty.
Played Front Suspension games on the Wagon again today, (replaced Strut bearings) just needs a little more tweakage and then she should be good to go for an alignment.
Rear Pads should be arriving soon... then rego retest.
Also a good chance She will soon have a GTR Clutch Fan. (RB30 fans are NOISEY and not so efficient.) ;)
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
