Nice work Chris! Is it a Bellmouth? Guessing you didn't break any bolts?
Yeah its a bellmouth. Jacked the car up last night and started spraying the wd40 every half hour. Must have had about 4 or 5 rounds and then a couple more this morning. Only took a ring spanner to break it and then fingers the whole way. I was pleasantly surprised after reading about some peoples nightmares... My struggles was with getting the cat mount to go around the new front pipe as it was a fair bit fatter then the stock system.. Had to get dad involved and he angle grinded part of the bracket out for me so that it fitted around the pipe. Once we had that sorted it was time to put it back together
Nice work you've done also :D
In fact it sounds like a few people have been busy bee's over the past few days..
Richard getting his hands dirty with an oldy but a swifty ;)
Ahh yes i remember grinding the mount.
The bellmouth is ok to fit, the jjr stainless split dump is a real pain because of less clearance and access to the nuts/bolts.
Like those ones on the engine side are a pain.
Anyway, good it went on easy.
John actually modded my JJR Bellmouth for ease of bolting.
(Heated up and hammered in the sides of the Bell a little) and he ended up just Welding the mount to the pipe.
Installed rear vision cover last night. Looks amazing. Also installed new Strut brace, it took a bit of love to get it on but it went on.
PICS???
is it just me or do you have a new photo in your sig everyday ?
Imagination is a wonderful thing Andrew, it leads to creativity, something the world needs a lot more of ... keep up the good work mate, the world needs you.
I`m going to "imagine" I know what your talking about :P
well I cleaned it, went to get the ipad for a photo ( SLR is flat ) and then when I got back it was covered in pollen shit... and next doors chicken was there, so I took a photo anyway
I also soldered all the twist and taped cables for the stereo
Edited by ..::R33GTS-T::..
thanks a ton man! she`s getting there :)
that chook is awesome haha, it jumps the fence and plays with my little border collie, the puppy is somewhat scared of it haha
Last time I saw a Chook, (only a couple of days ago) it got it's head chopped off with an axe.
True Story.
Both Skylines are COVERED in a really fine Mist of Sap. :(
sounds like sandpaper when you wind the window down.
Today I did not much car wise other than pull off the passenger side mirror on the Wags and superglue the broken bolt mounts as they are all broken. :(
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
