Yesterday; pulled down the ke55, found out that it has a 3k head on a 4k block.. was consuming a lot of water too.
Today; finally finished off my ebc installation, holy crap I've been missing out! Massive improvement in boost ramp/response and still the same power/boost setting :) I will have to spend the next few days tuning it a bit more. Cannot recommend enough if you think your wastegate is opening too early!
Todays Post brought me a set of Front Brake Pads for R31 and a Spare Pair of Headlights.
More tinkering under the bonnet to eliminate Sputtering flatspots. (I think it's fixed but then find it's not) :( But after cleaning up some electrical connections and swapping in my spare AFM I may be onto it... Maybe. :/
See how it goes tomorrow on the commute to work.
First day back today... Need a holiday already.
good luck rob! mine was spluttering before I changed the plugs (around 3.5k 4k) flat out, havnt driven enough to find out if I fixed it yet, tomorrow when I go buy a claybar will find out :P
i really hate fault finding im having a strong cut when i accelerate heavily after changing the clutch. Might buy a new fuel filter,injector cleaner and new sparks. As for coilpacks will have to buy a new set, is there anyone with 34 coilpacks known working that i can use to test out if theyre the cause.
nah i swap them out every 5000kms when i change oil but ive done it more frequently of late coz of E85. Im thinking of getting these http://www.ebay.com.au/itm/230640250253?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
If you are still looking for them when my car arrives, I don't mind lending them to you
Perhaps even the Tune/ECU. some form of boost cut under hard/sudden boost pressure
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
