Still removing paint.
Just needs the window frame edges cleaned up. I can sand very close, but theres still a line of paint. Waiting for mini soda blaster for that and plastics.
So it will be totally bare and clean before etch primer.
Go see John at Trojan Motorsports. He has 3 stags out there at the moment.
2 he just got and the 3rd is his daily.
He may be able to help :thumbsup:
Thanks mate, will do. :)
Just spoke to John, taking it in next wednesday to get everything looked at/sorted.
Cheers for the tip. :)
All traces of paint gone (where im gong to spray) original nissan primer is tough stuff, edges done, panel beating done.
A quick wash and wipe with prepsol then its ready for body filler and etch primer.
Never used good body filler before, always was cheap sht. I used to dread the bog sanding.
I love pro body filler! :banana:
Its so easy to work with and edges feather nice.
Now i feel free to shape it as i please.
The rear guard is fully covered again, when i started to bash it out i realized its been work hardened, and about to tear and split. Its had all the bashing it can handle.
So it has to be re bogged, i dont feel confident cutting it out and welding in a new bit. If i could find a new bit.
Added a little touch to the door cards....
Credit goes to RBn1 and his build as this was his idea:
did not want to say anything in his thread but
had mine done for over 10yrs. Time to redo it :P
but yes it looks the shiz
(wait till you put a mini coloured fluro in it that comes on when you open the door :whistling: )
i see no proof of this. =D
Ive just ordered a whole heap of stuff for the GTR including full LEDs for all the lights. Can't wait till they get here.
please don't use paint anywhere on the door panels
(my inserts used to be silver, so was the cluster surround, and gearstick A/C surround)
good for it's day but got dated quickly
Nah no paint or anymore CF and very little lights. Need more moneys first though.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
