Meh... they're just tips, they don't need to seal.
Eventually the muffler and exhaust will likely be replaced.
Speaking of which, I also purchased a 2.25 exhaust with muffler and multiple bends for $10. LOL
Should be a good start to cut and weld into shape. (when MIK has some time) :D
Got some R31 Low Front King Springs from James today (Sir son of rajab Von Van Winkel), need to get motivated to do them and have a crack at doing suspension bushes.
Nolathane - Control arm bushes - Trailing arm bushes (upper and lower) - Pan hard rod bushes & Ball joints have all been acquired.
Might get some Tie rod ends too.
Pedders quoted over $500 to fit the bushes and ball joints on the car or $260 if I take the bits to them.
The end results should be AWESUM though.
Pulled the left front driveshaft out today. I had a split boot :(
It was so badly split I decided to rebuild the outer CV. Pulled it all apart (6 ball bearings, star wheel and case) cleaned them all out and regreased.
Ran outta light, but only have to re attached the caliper and throw on the wheel and then it's back on its wheels :)
Judd, could have been easier and quicker to grab a recon and have removed and put in. $300 all up from memory. Although if you know what's what then it's only time and the boot and grease cheap.
Edited by Sinista32
Yea that thought did cross my mind, as well as dropping it somewhere.
Buuut I don't mind getting my hands dirty and learning while I'm at it, and as you know money isnt as free flowing as I'd like ATM :( the boot was an eBay job, and less then half the price of genuine and came with a whole lot of grease. So basically it was my time and $20 bucks
I put my wheels on went to take it for a drive and the driver side was binding up :\ turned out to be surface rust on the disc and the pads stuck to it.
Sorted it out and took it for a quick lap and all seems well. Its now needs a full wheel alignment due to the change of tie rod ends and new bushes in the arms but it definitely feels nicer :)
GREAT SUCCESS
Put the Front King Springs in the Wagz. That's Low Kings all round now and yes the front is now a little lower again. :D
Ball joints are goosed so I just jammed some more grease in there. Will either get new ones pressed in or new Lower Control Arms. $$$
Pulled out the old Lower Control Arm Bushes with a nifty puller I made and put the new Nolathane bushes in. 25 year Old Bushes were Farqued.
Still need to do all the rear Nolathanes but between the fronts and the King Springs SkyWagon Feels Soooo much better / Safer to drive. :bunny:
post-78856-0-47990400-1396769731_thumb.jpg post-78856-0-48971300-1396769733_thumb.jpg
The change from when I bought her to now is Amazing but still more to come. :thumbsup:
  • Like 1
Slow.
Not much time last week to do anything. When i did have time it was freezing cold and i thought getting all wet from sanding wouldnt be nice.
Got back into it last night, did a bit of sanding on the skim putty.
Looking at the door... the crease loses definition around the middle. Also the bottom "fold" is not sanded straight.
I think i can do it by taping a strip of alloy to putty/sand against, and get a nice straight line.
The rest is coming along well, only bonnet and rear guard need work and its not tricky, just more skimming and sanding.
Still haven't fixed my Drivers side mirror after the Goulburn Melt Down so I put my Ganadors on instead.
They don't match properly as they are Black but they look mad nonetheless! ;)
Guess I'll get used to the Tiny Bluish reflections.
  • Like 1
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
