  • Replies 58
At least it will sound alot tougher, I reckon the note is worth the price alone:)
I gotta admit I thought exactly that myself mate :Oops:
It does sound nice with all the changes. Can't wait to put cams in one day.
By the way I now have a sticker on my car, Boost Worx on front window. This new mod overlooks my bonnet and infuses its magic influence into my motor :wassup:
Matt, when's the next AIR run?
Steve uses his roll cage Martin, he hangs his clothes on it when the factory clothes hanger is already full :)
Yeah Steve, you can borrow my neons, did you want my plastic look-a-like intercooler too? :) Hey you know how I've got the leaking BOV problem? I was actually thinking of blocking the BOV fitting off and just using one of those pretend electronic BOVs instead. That way I get the sound, without the leaks!
Lach, I'm pretty sure the next AIR meet is on the 6th of June? As I mentioned in the PM mate, I'm heading down to BW on Friday. The plan is to trial a muffler change (current Trust muffler is very quiet, and restrictive) and have a play with the BOV in an attempt to fix the leaking issue. You should see if you can head to BW as well? We could do a back to back comparo'.
Rightio, might see you there.
6th JUNE?? ill be there with or with out the nittos. I need to run the damm car
Won't be in town for the 6th unfortunately.
By the way, I drive my car to work everyday and use it for work on occasions, getting good mileage considering, 390-410km/tank and alot more of course if a driving in country.
But that's Skylines for ya, brilliant, as per the editorial by Ben Ellis in a recent HPI.
How many marks does -5 degrees retard equate to on the os cam gears? I also have OS and the marks are totaly different to HKS.
Sorry but I have no idea, Shaun did it and I wasn't there. I'll ask next time I'm there.
Lachlan/anyone else: are exhaust cams a big benefit to a car without cams or extractors?
I have heard a couple of schools of thought and it seems that if they really did give a little more power but more importantly made the turbo spool up to 500rpm earlier, then EVERYONE would have done this very cheap mod.
I am looking to have it done on the essfideen and want your thoughts.
Andrew
Here's my thoughts on cam gears Andrew... (using Andrew makes me feel as if I'm about to tell you off :()
The stock cam profiles are designed to work with the stock exhaust system, turbocharger, boost levels and so on. The more you move away from the factory set-up the more you'll find that cam gear adjustment "may" make a noticeable improvement. I would've thought the stock cam timing is a compromise between power and emissions too?
We've made cam timing adjustments to my motor twice (the original motor and the built motor) on both occassions there have been noticeable mid range and top end rwkw gains with nil loss down low (retarding ex cam for mid/top power).
Why don't more people do the cam gear mod? I don't know? It seems strange to not do it if you ask me. It's cheap power!
Lachlan/anyone else: are exhaust cams a big benefit to a car without cams of extractors?
Andrew
Andrew, could you repeat the question? Not 100% sure what you mean re your first sentence....were you drunk :(
er have edited it now .... my damn typing skillz .... without cams or extractors (and by cams I mean normal valve-open-and-close type ie. 256 with lift etc, not exh cams - obviously.)
Matt - thanks for your response - I thought as much! Do you remember how much your exh cam set you back?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
