Yo, I've got a maroon series 1.5 R33 Skyline for wrecking here in Sydney. It's got a stuffed/blown auto gearbox, slightly dented roof and no rego so i'm just wrecking it !
If you're after anything listed here or any other random parts, reply or flick me a PM
post-35556-0-95342700-1355748072_thumb.jpgpost-35556-0-38843500-1355748083_thumb.jpgpost-35556-0-47407300-1355748244_thumb.jpg
Pickup in Sydney, or I can post pretty much everything anywhere in Australia. It's got some aftermarket parts, listed here first:
Aftermarket parts:
Kinugawa T67-T25G high mount turbo kit. Includes everything you'll need - Turbo, XSpower highmount manifold & 44mm wastegate (plumbs into split dump), 3" stainless split dump pipe, oil feed lines, hoses/clamps etc. Turbo is in immaculate condition, less than 2000km old. XSpower manifold is HPC coated black, also less than 2000km old - $1700 ONO
There's a massive thread with loads of info on these turbos here: http://www.skylinesa...dynamics-turbo/
post-35556-0-28419300-1355745834_thumb.jpg post-35556-0-63041800-1355746002_thumb.jpg post-35556-0-03117500-1355747125_thumb.jpg
HKS Hiper D height and damper adjustable coilovers, front and rear. Great condition - $700 ono
Carbon fiber bonnet, suit series 2 R33 (with s2 grille) Some small cracks / patches in the clear/coating. Includes bonnet pins - $400 ono, pickup only !
Apexi Power FC ECU to suit R33 Gts-t rb25det, good working condition - $800 firm
3" high flow catco cat, flanged to bolt right up to r32, r33 Skylines, S13s etc - $100
Also have a set of brand new / unused Nismo 555cc injectors. Still in boxes, with the nismo paperwork etc - $600 (these are still $900+ fron nengun, without shipping)
X-Racing FMIC & piping kit, suits R33 Gts-t. Good condition, includes all pipes and hose clamps - $250 - pickup only
SF-DIS-005 Splitfire coil packs, suits S1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Z32 AFM and matching plug, good working condition - $180
Oil Catch can - $40
XTR turbo beanie, the mesh on the underside is a little worn in one area. Will still work great though - $60
Set of 4x 17" R34 GT-T wheels and tyres. Wheels are in good condition, only a few tiny areas of gutter rash
Tyres still have pretty good tread- all 4 are at approx 50%. Unfortunately one of the tyres has a screw stuck in it and was (very) slowly losing air - $400. Can post if required !
PWR auto transmission cooler & hoses - $75
Blitz pod filter & adaptor, etc - $25
Also have a fiberglass R33 GTR front bar (with lower lip), no indicators/lights, painted Silver. Great condition - $400 ono Pickup only
Walbro fuel pump in R33 Gts-t cradle - $100 ono
(no pics yet)
The engine has approx 187,000k's on the clock and was running great. Rocker covers painted maroon
I did a compression test last week and it was great - bang on 150psi on all cylinders - $900 ono for the bare engine
Auto gearbox is still here but 3rd and 4th are blown (on the dyno) good for parts maybe? - $50
Exterior Stuff:
Series 1 headlights - sold pending payment
Series 1 reo bar, cut for FMIC - $150
Series 1 front bar (small section of the back of the lights was cut for FMIC, doesn't effect operation - $250 - pickup only
Front guards - $75 each
Bare nose cut/radiator support - $150
S1 grille - $60
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts - $150
Engine bay stuff:
Aircon condenser - $125
R33 aircon compressor pump - $90
R33 power steering pump - $100
R33 alternator - $90
S2 (no ignitor) Rb25det engine loom - $150
Engine Mounts - $75/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Brakes/driveline:
Front calipers - SOLD
Rear calipers - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front castor rods - $75/pair
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $140 pair
Handbrake drum assembly incl cables - $150 pair
Rear differential (4.3) auto diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Also have a full set of standard suspension - $150
Interior:
Complete set of floor mats, good condition - $80
S1 Front seats, good condition, small bit of wear/hole on the driver's side in the usual area - $120 - pickup only
Complete set of S1 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Driver side window switch (12 pins)- $75
Instrument cluster, approx 187,000km. tacho not working properly (jumping around) - $50
Painted dash surround & auto gear stick surround - $120. Includes boost gauge mounted in the cluster surround
Centre console, with good lid/latch - $50
Seatbelts (full set) - $100
Ignition barrel + door barrels & key - $90
  • Replies 40
Where abouts in Sydney? S1 grille still for sale and no clips broken?
St george area. Still for sale, 2 of the 5 clips are missing, still clips up fine to the car
Can you pm me your contact number please
PM sent
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
