Nismo Fuel Pressure Regulator $200 ono including postage
Brand New, Never Used, Never Fitted. Selling as I didn't end up needing it for my setup.
Fully adjustable from 28 - 85psi. It is a DIRECT bolt on upgrade ie no adapter needed and will fit sr20, rb25, and rb26
More info: http://justjap.com/s...248&cat=&page=1
R34 SMIC $100 ono
Perfect working order. Comes with pipe & bracket
R33 S2 AFM $100 ono
Perfect working order. Purchased from SSS Automotive in August and still has 7 months warranty remaining. Includes plug.
R33 S2 ECU $100 ono
Perfect working order. Pins unbent. Good upgrade for S1 R33
R33 Stock Intake Pipe $30 ono
Comes with original clamps (with the hole for the locating nipple)
Pick up Blacktown area. Happy to post.
Richard - 0421 202 823
Thanks
Yes it is still available but unfortunately it appears it will not fit RB20.
Nismo Fuel Reg Vehicle Compatibility:
- Nissan Stagea Autech 260RS
- Skyline - R33 GTS-t S2 - ECR33
- Skyline - R33 GTS-t S1 - ECR33
- Skyline - R32 GTR - BNR32
- Skyline - R33 GTR - BCNR33
- Skyline - R34 GTR - BNR34
- Silvia - PS13 (Red Top)
- 180SX - RPS13 S2 (Black Head)
- 180SX - RPS13 S1 (Red Head)
- 180SX - RPS13 S3 (Black Head)
Edited by Richard GTST
R33 S2 ECU - Sold
Also have a S1 AFM - $50
Nismo Fuel Pressure Regulator $200 $180 ono including postage
R34 SMIC $100 $80 ono
R33 S2 AFM $100 ono $50
R33 S1 AFM $50
R33 S2 ECU $100 ono SOLD
R33 Stock Intake Pipe $30 ono $10
Thanks
Has anyone got complete Dashboard for R33 1993 coupe postage,freight not a problem
Has anyone got complete Dashboard for R33 1993 coupe postage,freight not a problem as I don't have a clue what I'm doing chic thing I guess or just plain dumb can u contact me on my mobile 0447355100 plz all help needed lol
Julie
Edited by Alex'sR33
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
