Nismo Fuel Pressure Regulator $200 ono including postage
Brand New, Never Used, Never Fitted. Selling as I didn't end up needing it for my setup.
Fully adjustable from 28 - 85psi. It is a DIRECT bolt on upgrade ie no adapter needed and will fit sr20, rb25, and rb26
More info: http://justjap.com/s...248&cat=&page=1
R34 SMIC $100 ono
Perfect working order. Comes with pipe & bracket
R33 S2 AFM $100 ono
Perfect working order. Purchased from SSS Automotive in August and still has 7 months warranty remaining. Includes plug.
R33 S2 ECU $100 ono
Perfect working order. Pins unbent. Good upgrade for S1 R33
R33 Stock Intake Pipe $30 ono
Comes with original clamps (with the hole for the locating nipple)
Pick up Blacktown area. Happy to post.
Richard - 0421 202 823
Thanks
Yes it is still available but unfortunately it appears it will not fit RB20.
Nismo Fuel Reg Vehicle Compatibility:
- Nissan Stagea Autech 260RS
- Skyline - R33 GTS-t S2 - ECR33
- Skyline - R33 GTS-t S1 - ECR33
- Skyline - R32 GTR - BNR32
- Skyline - R33 GTR - BCNR33
- Skyline - R34 GTR - BNR34
- Silvia - PS13 (Red Top)
- 180SX - RPS13 S2 (Black Head)
- 180SX - RPS13 S1 (Red Head)
- 180SX - RPS13 S3 (Black Head)
Edited by Richard GTST
R33 S2 ECU - Sold
Also have a S1 AFM - $50
Nismo Fuel Pressure Regulator $200 $180 ono including postage
R34 SMIC $100 $80 ono
R33 S2 AFM $100 ono $50
R33 S1 AFM $50
R33 S2 ECU $100 ono SOLD
R33 Stock Intake Pipe $30 ono $10
Thanks
Has anyone got complete Dashboard for R33 1993 coupe postage,freight not a problem
Has anyone got complete Dashboard for R33 1993 coupe postage,freight not a problem as I don't have a clue what I'm doing chic thing I guess or just plain dumb can u contact me on my mobile 0447355100 plz all help needed lol
Julie
Edited by Alex'sR33
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
