GT3540r .5 front internally gated .8 rear with all lines and fittings - 800
Full 3" exhaust, 100 cell metal cat, (92db) with an extra 2.5" rear section to pass db tests - 500
Yelow jacket coil packs - 250
Modified air box with k&n filter - 170
Jim berry full monty clutch - 600
550cc jecs highflow injectors - 500
Power Fc ecu with hand controller tuned for above setup 284rwkw - 900
Apexi boost gauge - 150
Greddy turbo timer - 60
Gizmo ms-ibc ebc - 300
Walbro GSS342 255 fuel pump near new - 120
All items located western suburbs of melb, happy to post, also happy to do a package deal.
0424999936
bump.
apexi boost gauge in greddy a pillar pod - 120
gizzmo - 250
greddy turbo timer - 50
Jim berry full monty clutch to hold over 300rwkw basically new - 500
turbo back full 3inch exhaust flows awesome - 400
Jim berry clutch - SOLD
Gizzmo - 180
Greddy turbo timer - 40
Apexi boost gauge in greddy pod - 100
Turbo back exhaust - 400
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
    • This thread keps giving with the OMG!
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
