For sale I have my 1991 Toyota Soarer 2.5L Twin Turbo , (206kw)
This car is a nice quick sporty 2 door import.
Car has: 138 ***kms and 4 months rego.
Features of the car:
• Aftermarket wheels
• Front lip
• Boost controller with multiple settings as well as gauge and stat displays,
• Turbo timer
• Aftermarket cd player
• NOS kit (lines hooked up , bottle not included)
• Aftermarket smoked tail lights
• Aftermarket adjustable coilover suspension
• Aftermarket Koyo Raidiator (under 100kms old)
• Air intake modified for better flow
• Boost gauge
• New projector lights (hi beams)
• Twin turbo power
• Automatic
• Rear wheel drive
Car handles well and nothing beats the sound of the turbo spooling and flutter.
Car does need some love in a few areas and was bought with these as this is my weekend/project car. Drivers side door trim is stuffed (common problem with soarers) , air con doesn’t work and has been partially removed (panel and fan) , Car has a few small dents around body.
Overall the car is a great drive and looks good. It does some areas that need love as listed but this will be taken into consideration when it comes to price.
I am selling due to me needing some funds for new endevours. SO MAKE ME AN OFFER!
Price: $4 500
Please email or text as my work hours can sometimes be all over the place , so I would prefer a means of communication to ensure you get a response.
Phone: 0404 519 365 (text preffered)
Email: [email protected]
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
