saw these in the latest Tengoku being fitted to a s13
who's going to try them out first
after my 35 gtr afm testing I'm over trying things out to many wankers
who say they know better than the Japanese
http://blog.car-and-....jp/?eid=191254
What's the theory here??
By elliminating the striker gap the chassis is stiffer and the steering becomes more responsive........
Maybe if your driving an old Corolla but seriously a late model monocoque chassis.....
just cut up an old car tyre and jam it in there.
for it to do anything it would have to make the door harder to open and close. but i highly doubt that anyone would be able to notice the difference with or without them
Totally agree. The difference if any would be so negligible behind the steering wheel you wouldn't notice.
Seems they have moved on from magic earthing kits to magic door strikers....
coming from TRD i wouldn't put it them the same boat as those making earth wire kits
I'm not sure if that was a smart arse remark or not.....
I'd assume they are some type of before and after chassis graph that's been put together buy a Japanese marketing guru at TRD.
Things don't even need to work for companies like TRD and nismo to market them.
Nismo upper arms for the R32.......
The brackets are good but the arms are the same
S chassis castor rod mounts
Same as factory painted silver......
Nismo engine mounts.....
Ever cut both types in half and seen the insides?
Same same just new.
A late model chassis like the 86 would not suffer from extreme chassis flex that would be felt at the steering wheel.
The marketing for these claims more responsive steering. Everyone I know who has punted one of the 86's hard has commented how good the steering is. Chassis flex mustn't be that bad.
If it was then there would be massive amounts of warranty claims from door skins rubbing on door jams taking paint off like the original 350z convertible had problems with
Same same just new.
wasn't I hoped they made some sense to someone
all the nismo arms are claimed to have different bushes material used than the nissan stuff
most are braced, different length for more camber more caster etc
pretty sure nismo mounts are again made with different material than nissan mounts so there more rigid
I've never cut open a brand new nissan mount compared to a brand new nismo mount never had a reason to doubt the claims
I've just tried rocking my motors before and after and noticed a difference which I guess your saying is just new compared to old
the graphs probably show the "improvement" claimed by trd
Edited by 1400r
Same same just new.
don't forget the nismo sticker.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
