So for the last few months i've been filling up at around 300km. I have an Injen CAI and no other engine mods.
I just filled up then and my needle was just above empty (i do realise that the needle is a little incorrect)
I filled up the tank today at 287KM and my car took 41L of fuel, i know the tank holds 80L but i have never driven the car to completely empty, in fact i don't think i've even done over 400km to the tank.. I feel so stupid because i've been filling up way before necessary, with the driving i do i should theoretically be getting close to 500KM to a tank.
Facepalm.
https://www.sau.com.au/forums/topic/416439-whats-your-average-km-to-a-tank/
I usually get around 600km before filling which is usually just after the fuel light comes on. I usually manage 11.5L/100km in winter. And about 12.0L/100km in summer (heavy AC use in summer). Which gives me a theoretical range of 660-700km per tank.
All light city driving.
6MT sedan. With shell 95RON fuel.
Edited by sonicii
I usually fill at 1/4 left by which point there's 400km on the clock. Was avg 12l/100km. No ac, start stop traffic though. Stock as a rock.
After changing the diff fluid, this seems to be getting better. Now looks like closer to 10l/100km but we've been doing a lot of motorway Kim's during this season.
Mines stock and I got 730km driving from Sydney. Around town I get around 550 ish
That's impressive!
aha I don't even trust the needle anymore, i just watch how many km's i've done and where i've been driving/how i've been driving then fill up when i deem approprite. But this time i've going to let it run to 500 then refill and see how close to empty i am then.
I have only done 1 highway trip in mine. Townsville - Yeppoon and return.
1 tank each way, about 740km. Low fuel light had just come on when I arrived in Yeppoon. After filling in Yeppoon, i still had 1/4 of a tank left when arriving in Townsville.
From memory, I averaged about 7.8L/100km overall.
After reflashing with the Uprev software, my first full fill up on 98 till now was 790kms. Not even kidding. Will be interesting to see if this can happen again... :S
Did you drive to Sydney?
Cruise control 95kmh behind a road train?
James sometimes an automatic with cruise control can actually be worse on fuel than a manual because of the constant gear changes. At least i know for a fact this is the case for the mid 2000 model Prado's.
Good question.. under want conditions did you get 790km from 1 tank? if it was highway KM, then this is about normal.. if it was city driving then it is very impressive.
I'm guessing that must be highway km unless he's driving a little 1.5L v4. Max i've gotten out of mine for highway km is about 700 and that's with a little bit of enthusiastic driving.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
