Adam - that's nice average power.
When my R33 was stock I get 145 rwkw with just a zorst & pod.
So 162 with auto is pretty good, I'd say. What is the boost set to ?
What does the seat of your pants say ?? Can you feel the difference ??
Meggala,Yeah I am. I can feel that flat spot but I haven't had a chance to drive it properly yet since the AVC-R went in on friday. Makes me wonder about all these guys with 200 and 250 rwkw though.
Obviously I know that I have an auto and there are power losses there but that was my choice for comfort in Sh!tney traffic.
Here are my first dyno sheets.  Car is an R34 GTT auto with full exhaust and AVC-R boost controller.
What do people think?  Is this alright?
looks good adam. with the tiptronic gearbox i think you should be reading slightly higher than manuals because of gear ratios. and i also believe auto/tiptronics have a different ecu....but dont quote me on that :P from memory (i'll have to dig it up) i got 154kw on the same dyno with about the same amount of mods.
1 tip - FMIC. i didnt notice any seat of the pants difference and thus that represented zero bang for dollar!!! for a street car, i think the side mount is perfect for power levels close to 200rwkw. when you do some trackwork or get a bigger turbo then i think this is where a FMIC starts to get important.
spend your money on a handling pack from say whiteline. what are you after? track stuff? street?
3rd gear for me and 4th for you is 1:1 but I'm not sure if this takes into account the diff or not.
I do like the track which is why I thought about getting the FMIC. I'm also leaning towards whiteline for suspension.
I've got to get some decent tyres too.
Robo: Yeah they certainly seemed to wring it's neck on the dyno didn't they. I went to 7k last night when I miss pressed the button to change into 2nd gear. It didn't seem to hit any rev limiter.
Franks: I was going from memory but I think it touched that mark once at Eastern Creek. The rest of the time it stay a little under that even after 15 minutes on the track. It behaves so well. Brakes never fade, never overheats, once got at A/T light to go on but that was at the end of a track session with the last two laps basically being drift laps at Wakefield the other day.
Benm: seems it took 5.5 hours :)
I had a proper drive last night and that flat spot is quite annoying but the rest of it... mmmm... power.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
