Ive been a close personal friend for numerous years and have contacted Kristian of Iron Chef Imports about doing a drive to his funeral on Thursday for those who are interested.
Ive been working behind the scenes with his family to help ease some of the problems they are encountering.
The funeral is set for Thursday the 10th at 3pm, Blackwell funerals on prospect road.
For those who knew him or had good dealings with him and would like to participate, please feel free to come along and join in. His car was a big part of his life as was this forum.
It is unfortunate that we are not able to bring the car along. Because of some legal red tape (police) we can not currently move his car, so it wont be at the head of the pack like we were originally planning.
If anyone has any suggestions on meeting places, please feel free to add in on this.
Thank you in advance to all.
I could be a maybe at this stage. It all depends on what happens at work tomorrow. I will put busy on my calendar so there are no last minute meetings. I will confirm after work tomorrow.
Meeting at Tea Tree Plaza near McDonald's at 2pm SHARP for those who want to cruise down together, but we need to be at the funeral parlour:
https://maps.google.com.au/maps?q=blackwell+funerals+prospect+road&hl=en&ll=-34.88579,138.593903&spn=0.083643,0.184364&sll=-34.885816,138.593973&sspn=0.000933,0.00144&t=h&hq=blackwell+funerals&hnear=Prospect+Rd,+South+Australia&z=13&layer=c&cbll=-34.889219,138.59421&panoid=QpgQE5Q-YvyhJXi4atDXkA&cbp=12,118.56,,0,0
By 2:30pm to arrange the cars out the front. The funeral service is a very small affair, so we're going to drive off (quietly!) once the service has begun.
Thanks to all of you able to help. Any dramas, my number is 0402 904 069 if you need to call.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
