Big Brake Group Buy #2 - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
Ok sweet - I will update thread over the weekend.
Full money ready once we have 10 people for the next batch. Nothing required until then (I will PM everyone once we get close to 10ppl to remind) :)
How far does the caliper on the 356mm setup protrude perpandicular to the mounting face of the disk? Just trying to work out of these will clear the spokes on my high-offset RPF1's, as I needed an ~8mm spacer to clear my stock GTT brakes.
There was some info on it, in the first thread:
http://www.skylinesaustralia.com/forums/topic/413182-big-brake-group-buy-skyline-silvia-stagea-wrx-evo-all-makesmodels/
Have a read and see if it covers the question, if not post up again and see if we can search for more detail :)
http://www.skylinesa...ll-makesmodels/
Thanks for that Nismoid.. I did see the post towards the end of that thread from Aaron.. Are there technical drawings available of the kits from D2? I really only need two measurements, caliper protrusion from face of disk hub, and radial distance of caliper from center of disk. Sorry for the big ask, I really want to run these wheels without spacers and if I can manage this with a brake upgrade then its win win!
Paul - Had a chance to call past IM yet to see about 380mm?
Everyone else - Updated as below.
Thanks for that r31, ill just get the anodized black 356mm for a r32 Gtr, when would you like the deposit
Added on - Race pad is $150 extra. Ok with that?
Deposit - not required. No money until we get to 10 people, I'll PM everyone once we get to 8 so you can get pennies ready :thumbsup:
I'll put an order in for Anodized Black 356mm fronts with race pads for an r32 gtst, with delivery to Brisbane.
Yep no problems also I live in Sydney
Yep that's no problem.
Hi Guys
D2 got back to me with templates for the 356mm 8 piston fronts. As it says on the doc, it's a guide and can't be used as gospel - ie if you have a bee's dick between the template and the spokes then a real world test fit would obviously be a better option :)
Cheers
Aaron
NI04-7-Model.pdf
NI05-1-7-Model.pdf
NI05-7-Model.pdf
NI06-7-Model.pdf
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
