hey guys just wondering whats best way of filling the dash of a 34 where there is light scratches, when i pulled stereo out (with towels) it slipped and made a few scratches
is there any fillers just to make them black? there not very deep just annoying now
what about texta, shoe polish?
cheers
https://www.sau.com.au/forums/topic/417299-scratches-on-r34-dashboard/
i will in a few days. its not bad but its defintly noticeable, apparently theres a product car yards use to cover all dash/interior imperfections. im just after a filler to dull the scratches thats all
its not worth going dash doctor though
anyone got a DIY ?
No good fix exist
Black shoe polish and a rag is the best way , you wont find a good dash in australia unless its packing a stock radio no freq expander
The monkey who puts in the expander farks the dash
Recover the lower dash in suede 30 bucks and some time cussing
Edited by Carbon 34
i was going so slow and gentle but the design of a 34 dash is absolute bullsh*t excuse the french , barely any slack in cables and 400 plugs , gearknobs in way sitting a bucket seat
WOW
I agree!! I also have the same problem with scratches (not too deep, but annoying they're there) whilst i was pulling the dash out to change head unit, do some wiring work, replacing cluster bulbs etc. It's like the head unit is forced to hang on the wires and rest up against/rub up against the dash material and scratch it. Even with towels there, i find it was hard to work with lol, got in the way a lot of the time.
So a rag and shoe polish is the best option there is?
il give it a shot and post before and after pics, im waiting on climate control globes from 666dan
the globes just automatically started flickering im like -_- okkkkkk lets pull it out again fml
LOL exactly the way i feel when i have to open it up again. One of my globes flickered too, had to pull the legs out a little to have more contact and stay put.
Di noc would be an option but unless your spray glue it on its not going to hold long term
Even with adhesion promoter
The silicone / plastic oils leaches out from past vinyl protection and it falls off
Plus that much wrap is around 100 bucks and some of the curves inner and outter as it comes onto the dash and under steering wheel you would be lucky to get a wrap to make the bend without excessive heat stretch shine
You can do it in real carbon but it would look odd depmding If you had carbon center section ?
The side by your clutch leg rubs so the material must hold up without dying from rubbing
(You wont see it on stock unless you put your head down near it )
plus once you do the wrap your going to want to match all the panels ?? wraps are not the best option
The shoe polish trick works on all but the most screwed dash , if it has slice marks from the cage be sure to use care not to drag off the sliver of vinyl . Make sure you wipe the polish off good so it doesnt get on your clothes !!
the radios must be removed with rags blue taped to dash secure and gear stick knob off is best
Placed in second gear too
the cage is like a dull razor and wires too short the first go round
Edited by Carbon 34
Dash use this after clear water on a microfiber cloth
http://www.meguiars.com.au/products/car-care/glass-clear-plastic-and-exterior-trim/ultimate-protectant/
Let it sit on dried out plastic after buffing a min
Apply twice if its streaky
The plastics absorb weird if they havent been detailed in a while
Plastic gauge bezels - plastics polish from megs or mothers
Glass use above or eagle brand in shade
Always use microfiber cloths and wash Without fab softener or it will streak forever
Cloth use bissel spot cleansr for couches ( same stuff pros use and megs products )
The megs airfreshener works without stink
Carpets replace or steam clean and dry outside with windows open till 100% dry
followed by scotchgaurd on seats and flloors , door inserts , but painter tape off the door plastics first
Leather Steering wheels use saddle soap followed by the clear waterproof or black boot polish then buff off well
  • 2 months later...
hey Mike i used the black shoe polish it was pretty good, make sure you get a good chunk of the polish on your cloth and just lightly rub it over the scratches and all around it too, looks nice, doesn't smell too bad either (ahhahaah)
  • 4 weeks later...
  • 4 weeks later...
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
