It's got less kms than your motor, so should by all accounts be in better condition. If you are doing that, put a little amount of copper seal around the plug Seals.
I think there is a rubber line outer seal to replace too, that sits in the cover? Scotty? Should only be a couple of bucks.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205239
Yeh, the rocker gasket is around $25.
I don't like putting sealant around them, as a thin smear might fall off and partially block the oil pump or pickup (as there is nothing to hold the sealant in place). I try to minimise the use of silicone inside the engine for this reason.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205256
Should tell nissan that... Whole thing is held together with sealant! :P
I never had an issue with it when I was changing sumps over. No sealant disappeared. As long as the instructions are followed, the stuff works well.
If you use tons of it, and clamp it down hard immediately, then your right, you're in for a bad time.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205318
I will say it again for the deaf among us... There is nothing to hold the sealant in place, and nothing to clamp it.
As the tube is covered in oil the sealant won't stick, and there isn't another mating surface to hold it in place, hence why it will break off and float about the engine. It's a slightly different application to sealing the sump as there is a 20mm lip holding the silicone in place, plus you would be able to scrape it clean first and brake clean it.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205325
I see what Scotty means.
The sealant wouldn't help. It's just a thin metal edge.
Yes, but Nissan still used a little sealant on the cover gasket, at least mine had some when I removed it. Someone should tell those engineers the theory & see what they think....
On sealing around the spark plug tube, totally agree - it's pointless. Better to syringe it out every so often than risk it.
Edited by Commsman
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205404
It would have just been nice for them to just round off the spark plug tubes at the end to just a little flat surface, so it would seal better. But alas, I suppose the accountants got in their ear. Probably one of those will it last 3 years/100k kms things. Even the old honda I had (honda boi!) had a better mating surface.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205433
How do you deal with no vtec? It must be so boring driving your s13.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205494
Hahahahahah
My little shitbox didn't even have vtec! It was a uni student car.
I think it was before the whole vtec fan boi thing. The vtec models were pretty expensive in 2002, so kids couldn't afford them.
  • Like 1
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7205499
  • 1 month later...
Nup, it was actually on the quarter mile it blew up.
The motor was suffering massive amount of Det, and was shedding the electrodes from spark plugs. One may have come off and rattled around, but it looks as if the det blew out the side of the piston rings too. You'll see more once you remove the piston and rod.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/8/#findComment-7234469
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
