Hi headlight guru.
I am looking to do this to my r32 gtst skyline later on during the year and was wondering if I could ask you a few questions.
Would i get the same stuff or would I need some specific items?
I want to make it dual high beam and low beam if possible.
also would getting the kit from that website be better?
any help or recommendations is greatly appreciated.
Thanks
I'm doing the retrofit to my R32 lights. I am assuming you have projectors lights (which most R32s have).
Get the FX-R projectors (RHS, 3" lens) from TRS. They go on with not much effort, don't need to make brackets up. Just need to tap one existing hole and drill + tap another, and they go straight onto the adjusters. Also order a pair of AMP > D2S straight adaptors (this). Yes you can find ones in China for $5 but you have to wait 1 month for them to come, whereas the TRS stuff usually turns up within two weeks.
Get D2S HID kit, like this one. 4300K temperature is best. I found that recently, the cheap HID 4300K bulbs aren't 4300K but more yellow. Good to invest in something better I suppose. I will find out very soon if the bulbs in that kit are good.
For dual high beam, I wired up an 'anti-flasher' relay wiring for the headlights using three relays and diodes. It allows you to flash high beams while still retaining the lowbeam (so essentially they act as two separate circuits, so the lows don't turn off when you high beam). Might be a bit more complicated approach, but then you can always use something from TRS.
Butyl rubber glue stuff you can source locally.
  • Replies 57
Get the FX-R projectors (RHS, 3" lens) from TRS. They go on with not much effort, don't need to make brackets up. Just need to tap one existing hole and drill + tap another, and they go straight onto the adjusters. Also order a pair of AMP > D2S straight adaptors (this). Yes you can find ones in China for $5 but you have to wait 1+ month for them to come, whereas the TRS stuff usually turns up within two weeks.
Get a D2S HID kit. 4300K temperature is best, although I found that the cheap HID 4300K bulbs are more yellow. Good to invest in something better I suppose. Get 'F3 Start Bright' ballasts and your choice of bulb in 5,000K. Don't bother with 4,300K unless it's Philips/Osram). Don't bother with 'Hyluxtek' as I did back-to-back testing and the F3 Start Bright ones are a lot better and not noisy.
Whoops stuffed the edit up. Ignore my previous posts. Don't bother with the HID kit I listed, get F3 Fast Bright kit and optionally a better bulb.
Edited by niZmO_Man
Hi Nizmo man,
Thank you so much for the very informative information. I will definitely be doing this very soon.
Did you find the 5000k HID kit bulb a bit too yellow or just right?
Also, I might get something from TRS for the dual high beam
Thanks heaps once again.
Hi Nizmo man,
5000k HID isn't going to be yellow at all. If anything it will be a bit blue. 4000k is white, anything above starts going blue, then 10k starts going purple.
6000k is my preference for light output vs aesthetics.
5000K will be white white, as seen on Merc S-class cars.
Whether 4300K is white enough is personal preference... And your parker lights lol.
I haven't used 5000K as of yet. I always get 4300K, but I got a pair of 6000K from Mars performance in my R31. I find then a tad too blue for my liking. I think 5000K is good for looks vs. light, but as stated 4300K is best (daylight) if you want to actually see. The Mars performance bulb is actually very good. Back to back testing they easily surpass the el cheapo bulbs and even the TRS ones.
I'm currently tracking down a pair of 5000K, so will provide some pictures once I do find some.
Surprise surprise, projectors makes a difference after all! 4300K is white and I'm very happy with them. I'm not going to bother with 5000K bulbs.
Ordered a pair of Philips 85122+ bulbs, lets see the difference compared to the Chinese stuff.
  • 4 months later...
Very interested I can your results
Sorry man, forgot about this thread.
The Philips bulb is a bit yellow-er (probably 4200K) but they apparently colour shift as they get older. The output is no different but the spread is better (e.g. cutoff is cleaner).
But cant you just change to a phillips d2r 6000k bulb but use the same ballast? Or doesnt work that way? So would you recommend phillip or bosch? I cant seem to find it online :( can anyone link me please? xD
Edited by Wongy
You can always throw a cheapie HID kit and it will get you going/will keep you happy.
Guessing you want something like this:
http://www.theretrofitsource.com/product_info.php?products_id=147
Doesn't have to be Bosch or Philips.
I'm sure someone with R34 factory HID lights can tell you what ballasts it has.
  • 3 weeks later...
I think I found the stock ballast, quick question, if I need to put the d2r adapter on will I need to take off front bumper to acess the ballasts under the headlights? Or can I access it by taking off the washer bottle and the intake on the other side, thanks guys :)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
