Was out driving my r33 S1 today when i noticed alittle miss under load every now and then. Thinking it was a typical coil pack issue i just took it easy.
It started to get worse and is clearly not a igntion issue, it apears to be fuel. Everytime i try to give it gas it hesitates but it will still idle?
End result was a tow truck ride home, and just to add insult to injury when i got it home it still runs and drives fine?!
This is a heavily modified rb25det but this has got me beat. Its never let me down before but reminds me of trying to drive it with a intercooler pipe blown off. (if that makes any sence)
Pump is still working, ecu tells me that the duty cycle on the injectors is normal. I did fuel up 30 minutes before i left but does not have the characteristics of dirty fuel...Somthing is failing when it gets hot, but what?!
Good brain teaser for the crew..
On a foot note, the only person that stoped to help me push the car off the road was a fellow skyline driver! Full respect mate.
https://www.sau.com.au/forums/topic/417535-mystery-fuel-issue/
My money is vapour lock
All symptoms sound like it
Depending in mods
Fuel boils in the lines or filter and the engine dies and wont restart for a while on hot days or lots or stop start driving
Next time it happens remove fuel cap and see if it starts that drops off over pressure in the tank
any leaks or water in the fuel does it
So does e85 fuel , ethanol and super hot days don't go together
Highly doubtful its vapour lock. Not with 40+psi behind it. Increasing the pressure raises the boiling point of liquids. And the pressure would push any vapourised fuel through the system quick smart.
narrowed it down this arvo, definatly fuel pump! Its got a bosch 040 in tank in it and over the past few days i had been thinking to myself that it seemed to be louder than normal??...took it for a drive today until it started playing up and i can hear the pump reving up and down all unstable.
So out it comes tomorrow!
Case closed,, thanks for the input guys
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
