gday ppls im fairly new to the modding scene but im eager to learn as i just got my first r33 gtst and i been hearing this sound om otherturbo imports where u can hear the turbo make a kind if ch ch ch ch wind down noise....i reakon this noise sounds tuff but i have no idea how to get it...is it from an aftermarket BOV or sumthin else????? ne help is appreciated
https://www.sau.com.au/forums/topic/41763-how-do-i-get-that-noise/
  • Replies 40
this noise i called compressor surge. Its caused by nt running a bov or blocking up the one you have.
it might eventually f*ck up your turbo. When the Throttle body closes the compressed air comes back and through the turbo. The compressor wheel the chops up the air.
Nissan put it there for a reason
correct me if im wrong but i believe sequential bov's make that noise while still venting all that nasty pressure away from your turbo. thats the difference between a normal bov and a sequential, sequentials make that ch ch ch noise...
dunno bout sequential, but my super sequential does that. its normal and healthy.
Guest INASNT
Sell ur car and buy a VL turbo if u want that sound :)
I had that sound when i got my new turbo setup and had no BOV's on. It sounds tuff but ***s ur turbo up, plus causes extra lag between gear changes coz the air going back around to the compressor slows down the blades during gear changes
or just buy a sequential, a new turbo is a bit of an overkill
i have a arc bov sequential that makes the noise, and is as good for the turbo as a normal bov
Guest INASNT
I never said to buy a new turbo.
And the sound any BOV makes is not the same as the sound the air makes when it gets chopped by blades spinning at over 80,000rpm.
replace your stock airbox with a pod filter. You'll hear the ch ch ch sound easier without having to replace your BOV.
I did this and it sounds freaking mad when I take my foot off the gas slowly.
I've got an A'PEXi Power Intake (pod filter) and I've been told it's one of the loudest.
mate, I've got 2 BOVs hooked up at the moment (stock plumbback and Blitz SS) and I get the flutter sound. Explain that. Is my BOV on too tight? No, as I can still hear the air pass out through the Blitz BOV...
A pod filter makes a world of difference.
Guest INASNT
The flutter sound is not the same as the DUT DUT DUT sound of air being sliced up by the comp blades
as far as im aware, differenty bov and filter combo's will give different noises as not 100% of pressure is released through the bov on ANY bov, some will always go back to the turbo, the better the bov the less that will travel back. so in many cars you will still here a flutter, just depend on how much u hear will be determined by the bov and filter and turbo and boost psi... correct me if im worng this is my opinion only
have you noticed how sequential or twin chamber bovs have 2 vacuum lines?
this is to open the 2 pistons.
these are designed that way to have less chance of leakage under severe boost applications.
that is the only reason for sequential or twin chamber bovs.
it does not make any sort of sequential noise.
a bov that is working properly should make a single release sound and nothing else.
sure the volume and pitch may vary (comparing a turbo smart to a HKS SSQV's high pitched squeek noise), but it should only make a single release sound..
not multiple chu chu chu or other chopping sounds..
if you are hearing ANY noise from the air filter on a car with an ATMO venting bov, then the bov is not doing it's job properly.
any sort of fluttering or chopping sound is from the turbo chopping the air and can be heard from the air filter..
the flutter noise can also be different from car to car depending on a number of things..
size of turbo, the material used for the inlet pipe, the intercooler, the type of material used for cooler pipes, the length of these pipes...
ever hear a skyline with a stock cooler and blocked bov and pod... it is like a trrrrrr sound.. then same car with a new FMIC and larger and longer cooler pipes, the sound is completely different.. reason is that the pipes are of larger capacity and the air is forced out with less pressure and the fluttering sound is changed to a more deeper and slower flutter..
I hope this makes sense..
damn i got a $600 bov on my r31 that flutters, time to get out the allen keys and loosen her up a bit i think
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
