hey guys,
I know this must have been covered at some point by im running out of options,
Okay so everyone knows the window motors are a common thing to f**k up on the V35's, thats all well and good my Driver side one buggered itself so I replaced it, had the 1/4 window down problem, used the correct "Window Motor Reset" process,
http://infinitihelp.com/diy/gcoupe/projects/infiniti_g35_window_motor_replacement_procedure.php
and it solved that problem but iccured another one,
NOW when everything is replaced the window will go up and down fine UNTIL it reaches the FULLY DOWN position, then it wont go back up, almost likes it too far down....
I can use the 1st-click to go up and down, and even the auto up, but use auto down or accidently 1st-click all the way down, its gone...gotta open the door up, take the mottor off. wind the window up manually a tad..then put everything back together and its all good....
I know loads of people have the initial problem but cant find much on this secondary problem....
Anyone???
Cheers,
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
