Thought id throw this up... Considering everywhere you talk to tells you shit differently. Anyone that has a question bang it here and someone may no the correct answer.
Mine is... If you buy a dieline or any import for that matter from interstate can you get RWC anywhere in the act or does it have to go to dickson? Also whats the rule with FMICs?
Cheers
https://www.sau.com.au/forums/topic/418311-act-roadworthy-questions/
When I moved from Perth to here my GTR was registered in WA. I took it to Ultimate Tunes, they did an inspection etc. I took the paperwork to Woden and had the plates swapped over that day.
Not sure about the FMIC.
hmm thats what i thought the go was but i was being told differently with the RWC... Interestink.
I believe it's *SUPPOSED* to go to Dickson, however if you get somewhere else to do the inspection then you should be fine. Mine didn't go over Dickson when i got the rego changed from QLD to ACT.
ACT gov website uses the words MUST go to Dickson in big bold print.
People have had interstate cars changed to act through normal inspectors and dickson...
I got one of my cars from nsw to act through a normal inspector.
As for fmic, the rule is if the car came with a fmic oem ie skylines and silvias etc they have a front facing intercooler outside the engine bay then you are allowed one as long as your intercooler piping and core has not required your reo or chasis cut to fit it, for skylines you can put your cold pipe through the floor pan as long as its not going to effect the structure of the plate under the washer bottle, or through the side just above the chasis rail providing there is still metal attached to the rail (a inch is enough above it)
Hope it helps
It's definently a nice car, but I don't just wanna make an impulse purchase. It's under consideration for sure, but I'm still keeping my options open because I'm in no hurry.
have you had a peak at it? its a very nice example of an evo!
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
