Hey guys, hoping no one would be interested in buying my car, therefore convincing me to not sell it.
As most of u know the car hobby sucks u dry - not in a good way either. // -- insert marriage, house, kids sob story here --//
If it does go, hopefully it's to someone interstate.. I couldn't stand to see it driven by someone else locally. :(
First, the bad:
Will need a new clutch, currently 'catching high'. Still drivable.
Rust spots behind mirrors - common area. Although not too bad, as the mirrors were replaced by owner in Japan.
A/C needs to be regassed
Details:
1999 series 2 Stagea RS4-S (therefore manual)
Purchased from importer on 06/2011
Black
78,xxx kms
Serviced every 5000kms, and will service upon sale if seller requests
Rego til 04/13
My baaahhhdyy:
Ganador side mirrors
Dolphin eyelids
Dolphin sideskirts
Takero front bar
N/A grill
Weather strips
Not too sure what rear wing is - looks nice tho
Original stagea boot may (ooohh!.. ahh!)
Parcel cover slide thingy <-- someone tell me
Combination of banana and berry air fresheners (amazing! you will want to eat the air!)
Under the bonnet:
RB25DET Neo
NGK Iridium sparks
Spitfire Coils
Airynx pod filter
Cooling Pro Stealth (black) FMIC
3" cat back
JJR Dump pipe
Venom 500 series cat
Shoes:
19" Work TE37 (minor grazes), rears on 15mm spacers
Achilles rubber
BC BR coilovers
Handling (fitted <1000km/s):
Whiteline front swaybar links
Whiteline rear heavy duty sway bar (BNR11XXZ)
Whiteline radius bushes
$16k - I think this is reasonable with what has been done to it. Now all it needs is an ECU and further engine mods.
located in Canberra, please PM or sms /call me maybe on O432 808 254
These pics from when I picked up from Importer:
All credit to StiinkyPoo for these pics!
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/418445-fs-1999-s2-stagea-c34/
Damn that's a sexy car mate, shame to see you have to sell it!
If I didn't already have one id take it! :P Good luck with the sale, Hopefully you win lotto soon and don't have to say bye to it!
Thanks guys, really appreciate it the comments. And that's what I'll miss about it.. not only the 'uniqueness' and the turning of heads as I drive by; but the smaller detail that only skyline owners can notice (ie frontbar, rear tail)
My loss is your gain.
  • 3 weeks later...
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
