No video of the Courier V Gallardo. In my crew, we race like men. Public roads where the footpaths are littered with prams and the streets are full of traffic.
It may be a slight advantage for the courier to race in these conditions since we cut his springs and squished a shitload of bundy cans (gotta keep hydrated whilst street racing) together to make lightweight lowering blocks for the rear. A hell of a lot of swerving in between daily commuter cars goes on in our races and the Gallardo just can't cut it with the factory suspension.
There's no doubt about it though, the courier is an absolute weapon and there's no need to spend big coin on a lambo. All that accomplishes is a loss at every set of lights.
Edited by kawasakirider
Nick? He couldn't organise a bang in a brothel with a fist full of fifties. :P
He's talking about the drags at willow bank every Wednesday. Go in, register, run. :)
Yes this, could have all kinds of match ups diahatsu vs Chris's pedo van, Tony's maxima vs Noel running.... They'd be close races ;)
We did a run the other week with just a few of the guys to a small pub for lunch, was actually pretty good.
I will still be floating around powerplay if it isn't cancelled, I mean it's sold out so if they cancel it they'd have alot of refunds to hand out
Edited by Captain Natro
No dramas, mate.
If you want the drop on our race locations, just send me a PM. We've got a Daihatsu Sirion owner ready to blow the shit out of a big headed R35 driver this Friday night.
I wana chop at the sirion in my charade 3 cylinders of fury what what ;)
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
