  • Replies 63
For those intending to enter the terms and conditions, as well as payment details are available at
http://www.autosalon.org/orderform.asp
If I have read it correctly the cost to enter as a club display is $50 each, but it will cost you more if you want to enter the DYNO CHALLENGE or SPL/ dB DRAG RACING CHALLENGE.
To enter as a club we must have at least 6 cars. (It may pay to have a few in backup as well)
As the club name is critical to how we are grouped it’s important we all use the same name, hence I suggest we use "Skylines Australia" and not abbreviate it to SAU. We will also need power, so if we will need to pay an extra $60.
PS Whats the chance of all enterants getting together to plan this. We can use my place if its OK with all of you. As time is running short, I would sugest we meet either this weekend or next weekend. What are your thoughts?
Guest Miss_Nismo
**** da police .... if we don't take our cars out at all, or sell them and buy falcodores instead, then they win. Yes getting defected sucks, but we can't not live our lives in fear. And as for the 'there will be a defect station here, here and here' .... just look at what DIDN'T happen at drift day (which was supposedly going to be defect city) - I only saw 1 copper all the way home - and he had pulled over a commondore :)
Yeah and if we don't protect ourselves, and get our cars defected, they are also winning. It's a win-win sito for those guys.
By avoiding getting defected, I'm just avoiding a lot of head ****s.
Anyway, I might enter still, just depends on the status of the skyline at the time :cheers:
Guest Miss_Nismo
Excellent Paul :P We've got to have the GT-R represented under the SAU banner!
Having a 'Skylines Australia' display without the almighty GT-R would be a bit like drinking zero-alcohol beer :cheers:
Edit: The only bummer is you wouldn't be able to do a dyno run on the Boost Worx dyno :)  Unless Shaun did the remove shaft option?
Here's the updated list of "potential" entrants:
4door_Sleeper (R33 GTS25t 4dr)
whatsisname (R33 GTS25t)
Envisage (R34 GT-t)
cell (R34 GT-t)
Nightcrawler (S15 200SX)
Steve (R33 GTS25t)
skipppy (R33 GTS25t 4dr)
Clint32 (R32 GTS-t)
Pawley (R33 GT-R)
MattR (S14 200SX)
Miss Nismo (R32 obviously not worth mentioning)
:headspin:
Shutdown
Envisage (R34 GT-t)
cell (R34 GT-t)
Steve (R33 GTS25t)
Clint32 (R32 GTS-t)
Pawley (R33 GT-R)
MattR (S14 200SX)
Miss Nismo (R32 GTS-t *worth mentioning, as it has a special engine*)
Hi Guys
Just got the word that my car is unlikely to be out of the spray shop in time for the show. :-(
This means that there is room for another 4 door :-)
I am still happy to help organise/coordinate this if it’s needed (as I am the one who started this whole thing anyway)
If there is a need for those entering to get together and plan it (or just meet and go for a cruise and talk) my place is still available.
Remember to get your entries filled in soon as there is a late fee for those who register in the last week.
PM me if you have any further questions.
If someone wants to run with this (and help 4door) that would be great! If need be I'll do it, even though I'm a tad busy atm.
Damn it! I just realised that Autosalon is on the same weekend that 'I' want to do go-karting. Bummer ;)
I'll post up a new thread for people to give a, 'yes I am 100% entering AS'
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
