EOI: High mount 260rwkw @15 pounds R33:
Large Turbo (i think it is a XS power GT40 or 35: 15 pounds = 260 rwkw
Nismo Coil Overs,
larger Injectors and Fuel pump,
Q45 AFM
Greddy Emanage engine management,
Greddy Profec boost control evc
Front mount + front mount spray system
Greddy Blow off
Nizmo Coil overs (not height adjustable)
17 inch advanti rims
Better brakes with the abs disabled
the usual other goodies: sound system, turbo timer, remote start, viper alarm.
Only flaws are the front bar and the bonnet the paint could be slightly better and cracks in the front bar....
a QUICK CAR THAT DOES NOT SQUEEK........ PICS UP TOMORROW
Price $10k ono (i am open to reasonable offers)
Contact: Chris 0488236950 and [email protected]
https://www.sau.com.au/forums/topic/419022-eoi-fs-r33-260-rwkw-10k/
  • 3 weeks later...
Hahaha... it's unfortunate that you're so frustrated over trying to sell it and I was interested in the specs and the possible 300rwkw but after seeing the pictures I just didn't find it aesthetically pleasing so i'm no longer interested. Starting to decide as well that i'm only going to upgrade to a GTR.
I thought I banned you from SAU for life Chris .... yet here you are under yet another alias .... I am now watching you - tread carefully.
Has a dog box too...bit has a pretty cool wine and then pop when changing gears... ok guys I am just trying to see whether any one is keen on buying my stuff- car etc..... thanks for the bumps anyway...
Did any one go on that imfs cruise last night? My turbo gasket has gone so I did not go along, plus it started all thevway out north in scumsville heheh
Good to hear from you again nightcrawler..... I wish I had kept those bildsteins that I bought from you six years ago..... I need some stiffer coil overs....
You have a few more titles now...... fast on yiur way to sau royalty hehehe
No, $2.5k as you would almost NEVER get it off defect here in SA (Regency Park here are absolute assholes - it would cost you more than $2.5k to stock it out to get it off defect and refit the mods - gearbox change, turbo/manifold change, original fuel pump back in, original ECU back in, Viper alarm out, turbo timer out, boost controller out, coilovers back to stock, oil cooler out, etc etc - they pick on EVERYTHING - in fact you would most liekyl come out of Regency Park with a significantly bigger list than when you went in (common)) - and it would be a HUGE headache to get it off defect in another state with SA rego.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
