Hey I definitely don't want to kill Chris's sale, but that is the harsh reality of modified cars. But you also have to consider that for $6,500 you are only paying for the engine and associated gear, gearbox and mods - it is a bargain.
It's a paperweight (to me in my personal situation) if I can't register it, I don't have the funds to buy a tow car and all the associated stuff for a track car. Nor do I have the space, time and money to buy a shell and transfer everything into it.
a laugh at 2.5k.... no way 2.5k for a 260rwkw line with the parts I have... just the manifold, 3.5 dump and external waste gate cost over 2.5k... what about the engine management and boost control thats another thousand then you have the rims the suspension and the rest of the exhaust theres another 2.5 to 3k. And then you have a dogbox. Huge oil cooler the size of a radiator and cooler The blow off valves-two of - now thats prob more than 6.5k just there..... and then you have the car and motor.... heheheheee what a laugh.... it says 6.5k firm - thats firm with defect,
The oil leak was just the oil spurting out of the oil dipstick when not inserted correctly and giving it a bit while still cold.... which i hardly ever did... hence all sorted.....
Agreed nightcrawler.... I would be perfectly honest to say I would be sad to part with it for that price..... I have just ordered new rear tyres too.....
It will drive back fine to qld.... I still need to buy the 20 dollar turbo gasket (being purchased tomorrow tomorrow and fit)..... that can be a pain to get the turbo off the exhaust manifold because of the amount of room under the exhaust turbine and the room between the manifold bolts and the engine....you can not get a socket and wrench in there..... I have found a shortened O spanner however made of high tensile steel in order to do it although it will still be no walk in the park.... just cracking them is the hard part once they are loosened it is easy.... :-)
buy it ---> drive it back --> de rego --> engineer --> re-rego --> skids + pics!
  • 1 month later...
MMmm would be an option but i do not have the stock parts turbo low mount manifold etc i only have the gduounk parts.... i am not too sure how much the box was... I will try and find out...
$so i take it this thread must be being kept hidden either that or people would not be looking for skylines with all of the goodies for such a price.......????
You can not really ever buy a modded car for with these mods for less than $12 thousand with that sort of power.......
Interesting that it has not had any interest / or sold or people look even look into it further....
strip, sell, make more than $6k :)
or strip, sell, buy stock parts, sell car, make more than $6k
just requires effort and a few slabs of beer with your mates
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
