Hello,
I've been told to clean my fuel sensor to see if that will help my gauge problems out. I've been linked a page to clean it (http://www.skylinesaustralia.com/forums/topic/363010-fuel-level-sender-cleaning-r33-gtst/)
But i can't find any info on where to access my fuel sensor, in my 1999 R34 GTT. People said in the boot you should see some screws? I've looked and failed to see them. If anyone can link me a guide or tell me where to look that would be a great help!
Cheers, Zac
https://www.sau.com.au/forums/topic/419324-r34-fuel-system-question/
Open your boot. Directly in front of you where the back of the rear seats would be, theres 2 grey trims you need to remove. One is a flat panel, the other is L shaped.. Pull these out. Next you'll see a metal square cover held down with 4 bolts and some wires running under it. Pull this off and you'll find some fuel lines and wiring going into the tank.
Unplug both electrical plugs, then crank your car as if you are trying to start it.. This will relieve the fuel pressure in the lines. Now carefully pull off the fuel lines (they are brittle, easy to break).
Grab a large flathead screwdriver and a hammer and tap the large black ring anticlockwise. It will unscrew and you will be able to pull the beige center piece out. Slip your arm down into the drivers side of the tank, and you'll find the metal cradel with the fuel pump on it. To the right of this is the level sensor. Its white and about 30cm long. Its clipped in awkwardly but if you have a look in with a torch you'll see how its held.
Slide it out and pull it apart carefully. Generally the plastic is brittle so again just be gentle. Give it a clean inside and then put everything back together carefully.
All sounds very similar to an R33, however, I would recommend using a piece of wood (tomato stake etc) instead of a Screwdriver to open the lid dealy.
A little more forgiving on the plastic ring. :)
Thank you! I'll be giving it ago tomorrow at some stage, hopefully next time i comment on here it will be with good news haha
Cheers, Zac
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
