Yeah but proven to bring boost on 500rpm in most applications I've even read somewhere boost come on nearly 1000rpm earlier. A mates mate had one for his 33 and he'd never seen a manifold that clean inside, the welds get ground smooth and polished almost, quality stuff really, and I guess the saying you get what you pay for shines here
yes very true ill look in to it a bit more i mean you want the best you really have to pay for the best i guess
on another note anyone seen one of these before come in a box of stuff with the car
good day today went up to mates to cut the section of engine bay i need to repair my laurels rusted bit out of his shell and found that his shell still has the clutch and break pedals and a manual dash cluster :) so good saved myself few $100
are yeah shit i was looking at that forgot about you umm i did see the fuse box i know there is a hole engine loom there but i cut it in half when i took the half of the car off but the rest is there i think message him and ask he would know whats there but there is defs a fuse box still mounted in side the car
well yesterday i sold the r32 thank god so now the manual gearbox will come and getting closer to doing the conversion spent today putting on the new steering rack boots and taking the aircon pump out (as it was left in there with just the pump and nothing else) still waiting on the manifold and other gaskets to come then put all that back on cant wait to drive it again even if it is auto
alright so im almost there with all my conversion parts ive got a question ive searched and havent been able to find the answer...
As im putting the 25 box on to the 25 motor what sort of sandwitch plate will i need to bolt up or should it bolt straight to the bell housing ???
Speedo is easy get a d22 navara speedo sender, get navara cog off (die grinder with cut off blade) drill r33 gearbox cog out to suit navara Speedo sender shafts size. Slide r33 cog onto navara speedo sensor shaft and use some lock tite glue on it to be safe. Put navara speedo sensor in box ad make a new sensor bracket to hold it in
yeah ive read a few things now about doing it hope it is easy just hit the other issue few mins ago got new steering rack ends and thinking they would be the same as s13 buuuuutttt no to small do you know what sorta steering racks they have?
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
